NO / NC contact of switch, either mechanical or electronic switch. I used think of a switch's "normal" state as
- Speed switch: Shaft not turning
- Pressure switch: Zero applied pressure
- Temperature switch: Ambient (room) temperature
- Level switch: Empty tank or bin
- Flow switch: Zero liquid flow
We have an Amalgamated Instruments temeprature switch written : terminal 5 Relay1 COM and terminal 6 Relay1 NO and we connected on terminal 5 and 6. When I measure the contact with power off is open. When power on at low temperature contact is closed. If I simulate temperature to more than setpoint the contact opens. This really made go made. What state do we consider when we say normally open for electronic switches. The model for the temperature switch is PM4-TCR-D-4E-A.
