Previous in Forum: Equipment Without Certificates According to IEC Standards   Next in Forum: Irregular Bending of 500KV Tubular Bus
Looking for a Suitable DC -DC Buck Converter Using Coupled Inductor /Reactor
09/05/2019 4:43 AM
Hello there,
Anser this post who knows Power Electronics well.
Take a look my buck conveter in attachment.
People may called it "Dropper
It has following properties,
1. Input is 120 to 160 volt DC/ 30 Amp
2. Output must be 110volt/30 amp(maximum). +- 5% regulation( contineous output should be 20 amps)
3. Isolated in both input and output circuit.
4. Shunt sensing.
5. proper feedback.
6. 2 switches gets OFF/ON alternately.
7. May be soft switching.
8. May be 90% efficient.
I am thinking to modify it because bulky reactor/coupled inductor.
It has high current application.
kindly suggest a design that has
1. Less switching losss.
2. Less stress on switch.
3. Less number of component.
4. ZVS or ZCS idea.
5. Suitable ripple minimization.
6. Suitable couple inductor design.
Re: Looking for a suitable DC -DC buck conveter using coupled inductor /reactor
09/05/2019 9:05 AM
09/09/2019 6:56 PM
People think this circuit is a joke. It looks good but I can not get any power out of it. Current circulates in the inductor and nothing goes out.
If I un-couple the inductors and add the diodes it works.
This circuit is nonsense indeed.
Because of ...
1. No freewhiling path/ diodes.
2. Energy storing device alignment is wrong for sure.
3. Inductors are parallel, means it fails to describe wheather its bridge type or flyback type.
4. In this application, user must think a power transformer with center tap winding in sencondary!
5. CCM or DCM mode circuits cant be explain, because stupid circuit path.
Register to Reply 2 comments
