Previous in Forum: Rotation of Generator in Opposite Direction   Next in Forum: Current Transformer Accuracy
OLTC Selection
09/13/2019 2:24 AM
Dear sirs,
OLTC is kept on high voltage side so that lesser current can be handled with ease.
For 132kV / 220 kV autotransformer, OLTC is kept. How is its voltage class and current is selected. Similarly, how to read the step capacity diagram?
Regards,
Re: OLTC selection.
09/13/2019 6:26 AM
Here is a link that explains how OLTC works.With video.
https://electrical-engineering-portal.com/4-essential-features-of-transformer-on-load-tap-changer-oltc
Lots more info on google;I suggest self study if google is available to you.
Re: OLTC selection.
09/14/2019 9:38 AM
Rated through current an step calculation for OLTC can be done from original transformer data. How?
The transformer is 50 MVA and it is 132/220 kV step up transformer.
Regards,
Re: OLTC selection.
09/14/2019 9:46 AM
I mean rated through current and step voltage...
Re: OLTC selection.
09/14/2019 2:37 PM
Some of the older nameplates have the current rating of each step. The OLTCs I’m familiar with are on the secondary side, and use saturable reactors to boost or buck the output voltage. They don’t directly handle the transformer winding current.
The transformer MVA rating should be maintained at the lowest designed tap (highest if indeed primary On Load Tap Changer) and at the lowest design voltage, as marked on the nameplate.
So the amperes allowed on the secondary will always be stated on the nameplate, regardless of tap position. You can use the rated MVA and rated voltage to calculate the amperes, if no other information is available.
Anonymous Poster (2); HiTekRedNek (1); rwilliams (1)
