Previous in Forum: Is Air Used as Plasma Armature?   Next in Forum: Battery Charging
What is the Life Time of Electric Plasma?
09/16/2019 5:36 AM
How much time will air ,at STP, remain as plasma if it is made by using high voltage electric field ?
Pathfinder Tags: Life time of electric plasma
Re: What is the Life Time of Electric Plasma?
09/16/2019 9:17 AM
Think of a spark plug in an internal combustion engine. If there is no fuel to ignite the arc disappears in milliseconds after the high voltage is removed.
Once in awhile a lightning bolt will "chase its own tail" and turn into ball lightning. AFAIK it is still a mystery what preconditions are required to make ball lightning.
09/26/2019 9:07 PM
I would think it depends on the temperature of the air and probably other parameters.
This link may give some information.
Register to Reply 2 comments
