Previous in Forum: HT Motor Tripped Without Any Fault Indication   Next in Forum: What is the Life Time of Electric Plasma?
12 comments
Is Air Used as Plasma Armature?
09/16/2019 5:34 AM
I have been wondering for some time on whether can be used as plasma armature is rail guns at STP.
I have seen a YouTube video in which , he first made plasma with high voltage and then push it forward with high current. I am wondering if such a system could work or not.
Pathfinder Tags: Plasma armature
Re: Is Air Used as Plasma Armature?
09/16/2019 9:43 AM
A railgun still launches a projectile using gas (plasma) pressure. This fantasy wishes to hurl lightning bolts. An electron beam in the air will scatter quickly.
09/18/2019 9:13 AM
"... A railgun still launches a projectile using gas (plasma) pressure...."
Does it?
09/18/2019 9:27 AM
Hooray! Somebody actually read my link.
There is still a projectile.
09/16/2019 10:18 AM
It is difficult to imagine how <...plasma...> can exist at standard temperature and pressure.
Conditions usually have to be somewhat severe...
09/16/2019 11:34 AM
I know that by applying high voltage across electrodes can make plasma in air at STP.
Good Answers: 804
09/16/2019 1:55 PM
To understand this effect, read up on Paschen's Law, remembering that you need TWO electrodes. A "Projectile-less Rail Gun" concept (as I interpret what you are after) presumes the "target" is electrically the other end of an electrode pair. How are you going to get the target to cooperate?
As to air being used as a plasma conduit, observe lightning for an idea on how difficult that would be. Millions of volts does allow the bolt to travel through air at "standard" pressure but the destination (earth as the second electrode) is still random and very difficult to predict.
09/16/2019 11:37 AM
I built a Jacob's Ladder once, using an oil furnace ignition transformer and a couple of straightened wire coat hangers. Of course, the plasma has very little mass, so very little momentum. Not much of a gun.
09/16/2019 2:21 PM
Yes maybe, but the range would be very short and ineffectual....
09/16/2019 2:47 PM
I would like to know on what basis you said yes.
Just for curiosity.
09/16/2019 3:57 PM
I said yes because it is possible ....but on a hobbyist level, not enough power. unless your expectations are very limited....
https://en.wikipedia.org/wiki/MARAUDER
09/18/2019 1:57 PM
09/17/2019 3:38 AM
Plasma cutters create a plasma using high voltage and air.They will cut through nearly anything,but the distances involved are very limited.
Here is a link with details:https://home.howstuffworks.com/plasma-cutter.htm
Register to Reply 12 comments
HiTekRedNek (1); Jerinsam (2); JRaef (1); PWSlack (1); redfred (2); Rixter (1); SolarEagle (3); truth is not a compromise (1)
