Previous in Forum: Calculating Losses In DC Induction Furnace   Next in Forum: Volume and Height of Liquid in a Barrel
TH400 Tranny Spurts Out of Vent
09/16/2019 12:53 PM
My old TH400 tranny has started to spurt trans fluid out of the vent. Have tried varying the fluid level, checked the vacuum modulator, checked the governor. It's most active when vehicle is in motion. Any ideas before I replace the unit?
Re: TH400 Tranny Spurts Out of Vent
09/16/2019 1:35 PM
..."Overfull, overheating, loose/cracked/damaged filter extension up near case entry, loose valve body bolts/leaks at valve body, or warped/mismatched pump halves are all potential causes for fluid venting."...
"I run a Rossler built 400 in the truck. It wasn't over filled, but about every 5 passes it would have may 2 ounces of fluid in it the overflow. I was told this was normal. 4110 lb truck @ 8.99 153.5 mph in the 1.4."
...."Sometimes they push oil. Many "builders" don't seem to have the ability or be willing to take the time to make a pump surface / stator half flat and many times the factory finish is not up to par with the pressures that are being forced through these today."...
https://www.yellowbullet.com/forum/showthread.php?t=1761962
09/17/2019 12:13 AM
Assuming you're not racing this at 150mph, my guess is an aluminum casing crack, allowing pressurized fluid direct access to a drain passage, passage not designed for any sustained return flow. Never ran across this in a GM Turbo 400, it's a venerable beast. Depending on age, a small inclusion in the casting can take years to finally turn into a hole. You'd think that the loss of pressure in the clutch pack or band servo would make the vehicle undriveable, unless maybe you might not notice loss of torque (slipping) in Reverse?
09/17/2019 11:37 AM
No racing, just cruising in my T bucket. But I've had it for 25 years and history before that is unknown. I'm ready to just swap in a newly rebuilt unit.
09/17/2019 12:27 PM
That’s a great run, she doesn’t owe you much!
09/17/2019 9:04 AM
The hydraulic pump may be sucking air under certain conditions causing foaming and overflow.
roy hammy (1); rwilliams (2); SolarEagle (1); SSCpal (1)
