Hi,
I am trying to size a pump for a 3/4 copper pipe system. The system includes 6 ells, 2 butterball valves, and the isolation valves on both sides of the pump. Flow is around 5 gpm.
The water-to-water heat exchanger is an old one I have lying around, but there is no information about it's friction loss available. It appears to be 3/4 inch cu pipe inside 1 1/2 inch cu pipe.
I ran the numbers using the "Copper Tube Handbook" to find the friction loss per fitting, and ended up with about 21.23 psi loss.
Then I ran it through the Global Spec. Calculator and found much, much lower friction loss. It came out as:
Pressure Loss:
0.525 psi
Head Loss:
1.212 ft.
So, any ideas which one is correct?
Thanks
