Hi folks,
We're currently working on a design project in a pre-engineering class for a pet food dispenser. We decided on a model which rotates to dispense the food over a time interval. It's coming along fairly well, but we've run into some problems with the motor - mainly in getting it to turn a precise amount to only dispense one compartment of food at a time when it is activated by the timer.
I believe one option (or the only option?) is to add some sort of gearing to it. Right now the motor we are using rotates extremely fast but has almost no torque. (When the container that needs to rotate is attached to the motor shaft, it barely even moves.)
I was wondering if anyone had some suggestions on what might be the best method to use to solve this problem. The weight of the disc that the motor will rotate will change as more and more food is dispensed, and i'm concerned that this will cause the motor's speed to vary (thus throwing off any attempt at precision that we might be aiming for.)
Do you have any suggestions? Thanks.
