Previous in Forum: Available fault current in a DC system   Next in Forum: Current Carrying Capacity
Step up Transformer
10/22/2007 12:20 AM
I require a step up transformer as under
Primary : 415 v 2 phase a.c. 50 hz
Secondary : 1250 V 6.5 amp a.c. 50 hz
Could anyone provide some detail
We can use CRGO or CRNGO laminations.
Pathfinder Tags: Step Up Transformer
India - Member - PROFESSIONAL Engineering Fields - Power Engineering - electrical planning - designing
Re: Step up Transformer
10/22/2007 2:41 AM
Dear Nilesh,
RFE. Your question and my Answer dt.15Oct 07.
You are writing 2 phase 415 VOLT, DO YOU MEAN 2 PHASE , 2wire OR You are going to connect two wire from 3 phase/ 3 wire , 415 Volt system.
Please be specific. What load you are going connect for 1250 V, 6.5 Amp ?
10/23/2007 12:21 AM
I also assume that you are intending to connect it across two phases of a three phase system and that it is therefore a single phase transformer.
To make what you want most efficiently we need to know what type of load will be connected and whether it has a 100% or other duty cycle.
Where are you located? If you are in Australia we can probably help, and you may want to contact me on sales@dyne.com.au so that we can discuss your application.
Cheers
BigBird
fsmit@dyne.com.au
Register to Reply 2 comments
You might be interested in: Power Transformers, AC-DC Adapters, AC Motor Drives
