Previous in Forum: Separation   Next in Forum: China is Building Coal-fired Power Plants in Other Countries
37 comments
Coal Seam Fires Pour Out CO2 and Poisons
11/08/2019 12:51 PM
Pathfinder Tags: coal seam fires
Re: Coal Seam Fires Pour Out CO2 and Poisons
11/08/2019 1:55 PM
Well, you can't remove the fuel, so that leaves oxygen and heat.
"Extinguishing a coal fire requires cooling the coal and isolating it from both the heat and the oxygen that feeds combustion. Surface fires are the easiest to put out, with firefighters creating moats or breaks to keep the fire from spreading and then smothering it in a nonflammable material, most often clay. Slightly deeper fires can sometimes be quenched by digging out the burning coal—in Indonesia, crews have done this by hand—and then burying the entire area.[3]
But fires that rage deep underground, fed by oxygen coming from cracks in the earth, are extremely difficult to deal with. Most solutions involve pumping some combination of mud or fly ash combined with an inert gas or water, but the mixture does not always flow thoroughly enough to cover the burning coal, and it can crack when dried, allowing oxygen to get back in.[3]
In the 1980s, a Texas firefighter named Mark Cummins developed an improved system to produce fire-fighting foam. In 2003, he used the nitrogen foam (made by condensing a laundry-detergent-like material) to act as a blanket, separating fire from the oxygen that fed it to help extinguish a blaze in West Virginia’s Pinnacle Mine. Since then, Cummins has developed a foam that is loaded with microbes - after he puts out a fire with the nitrogen foam, he shoots the second foam into the mine, where the microbes will consume oxygen and replace it with carbon dioxide: “At that point, you couldn’t burn that mine if you set off a bomb down there,” he said.[3]"
https://www.sourcewatch.org/index.php/Coal_fires#:~:targetText=Extinguishing%20a%20coal%20fire%20requires,nonflammable%20material%2C%20most%20often%20clay.
11/08/2019 4:54 PM
Foam was exactly what I thought would be a good idea for the down deep fires. I didn't know that anybody had the solution already. It seems that the various governments involved have not made this a priority. I can't think of an excuse for that.
11/08/2019 2:05 PM
..."Coal fires are a problem all over the world. Such fires endanger nearby communities, waste precious resources and produce tons of noxious and greenhouse gases. Centralia is not the only coal fire burning in the United States. In fact, it’s just one of 38 burning in Pennsylvania alone. The hundreds of underground fires in the United States, from Pennsylvania to Alabama to Wyoming, combined with the thousands thought to be burning in China, India and elsewhere, are one of the largest sources of carbon dioxide and pollution on Earth.
China alone loses between 100 million and 200 million tons of coal each year to mine fires, as much as 20 percent of their annual production, according to the International Institute for Geo-Information Science and Earth Observation, based in Enschede, Netherlands. The Institute estimates that carbon dioxide emissions from these fires are as high as 1.1 billion metric tons, more than the total carbon dioxide emissions from automobiles in the United States. Second to China is India, where 10 million tons of coal burns annually in mine fires, contributing a further 51 million metric tons of carbon dioxide to the atmosphere."...
..."Now, a commercial firefighting company, CAFSCO Fire Control, based in Fort Worth, Texas, has its sights set on Centralia. The company’s compressed nitrogen foam system — originally invented to combat forest fires — has been adapted to fight underground coal fires with much success.
“There are no limits to the types of mines or size of fire that we can put out,” says Lisa LaFosse, co-owner of CAFSCO. “We can fill up any mine with foam,” she says. Furthermore, adds Mark Cummins, founder and co-owner of CAFSCO, the company’s system is safer and more cost-effective than the tried-and-true technique of digging out the fires. “We can put out a fire at a tenth of the usual cost, and we don’t even have to see the fire to fight it,” he says. CAFSCO’s method would also allow for future mining of an area’s unburned coal seams, unlike digging out the fire.
CAFSCO’s biodegradable fire-suppressing foam works in a number of ways to put out underground coal fires. Pumped into an underground mine through surface boreholes, the foam quickly expands to fill all the available space, saturating the interior of the mine from floor to ceiling, effectively soaking all the fuel and smothering the fire. The expansion of the foam also creates positive pressure in the underground spaces of the mine, forcing out any unconsumed oxygen that could further feed the fire. CAFSCO’s foam differs from other types of firefighting foam in that it contains no oxygen, only nitrogen, which works chemically to smother the fire.
The system has worked in dozens of coal fires across the United States, according to CAFSCO. In 2007, CAFSCO put out its largest coal fire yet, pumping more than 700 million gallons of foam into the Consolidated Buchanan No. 1 coal mine in Claypool Hill, Va. Cummins says Centralia could be put out in about a month, for about $60 million. “I understand the difficulties of the Centralia fire, but I know what this foam is capable of doing and I really believe we can put it out,” he says."...
Good read...
https://www.earthmagazine.org/article/hot-hell-firefighting-foam-heats-coal-fire-debate-centralia-pa
11/08/2019 2:34 PM
I would start a go fund me page and get all the greenies on board, then get this foam guy to do this in sections...
..."Then, two years ago, Michalski drew up a new, detailed plan to cut off one of Centralia’s four main fires. “Centralia’s fire is shaped like the letter H, with four limbs moving off in four different directions,” he says. Michalski, who has drawn up successful coal firefighting plans for several other Pennsylvania fires, proposed cutting off the fire’s northwest limb by filling strategic slices of the mine with coal combustion ash that wouldn’t fuel the advancing fire. “If this method worked on this one limb, we could then build three more barriers and effectively contain the fire in a box where it could eventually burn itself out,” he says.
Michalski took his idea to PDEP and was met with a lot of positive feedback, he says. But, to his knowledge, no further action was taken by the agency."...
...by isolating smaller branches of the fire they could work on one section at a time making the effort more affordable and manageable...
11/08/2019 10:07 PM
Gizmodo, huh?
11/08/2019 10:34 PM
Your question leaves me guessing. Gizmodo was not listed in Allsides.com, but
https://mediabiasfactcheck.com/gizmodo/
11/09/2019 1:47 PM
Gizmodo was the very first name mentioned in your four links in the OP. And that leaves you guessing?
11/08/2019 11:05 PM
Apparently not much motive to put this one out:
kdvr.com/2016/11/15/120-year-old-fire-still-burning-in-colorado-town/
11/08/2019 11:25 PM
"The Tiptop underground coal fire in Breathitt County, Ky., typifies the results... The origin of this fire possibly occurred before mining ended at Tiptop some 80 years ago... In May 2008 and January 2009, a team measured the emissions and metals in the area. The carbon monoxide emissions reached 600 parts per million (ppm) in May and more than 700 ppm in January whereas the carbon dioxide emissions were 2 percent by volume and then over 6 percent by volume. These concentrations exceed the U.S. Occupational Safety & Health Administration’s (OSHA) eight-hour safe exposure limits of 50 ppm of carbon monoxide and 0.5 percent by volume of carbon dioxide. Mercury was detected at greater than 500 and 2,100 micrograms per cubic meter in May and January, respectively, exceeding the OSHA eight-hour exposure limit of 50 micrograms per cubic meter. During both sampling periods, the team also found numerous volatile organic and carbon-sulfur compounds, including benzene, toluene, ethylbenzene and xylene.
earthmagazine.org/article/rising-global-interest-coal-fires
11/09/2019 12:51 AM
Maybe you could bomb them with plastic explosives to eat up all the oxygen and collapse the cavities....or bunker buster bombs....
11/09/2019 11:36 AM
I think pieces of dry ice should be tried. They would tend to remove heat and oxygen at the same time. Even regular ice with enough quantity should be tried. Has it been tried?
11/09/2019 12:54 PM
Dry ice is prohibitively expensive to begin with, but getting any ice down to the fire is virtually impossible....
11/09/2019 1:03 PM
Not in every case
11/09/2019 2:44 PM
Have you ever poured water on molten lava...?
11/09/2019 3:19 PM
I would want to use a helicopter on the one shown for China, but using a trebuchet for ice might work:
en.wikipedia.org/wiki/Coal-seam_fire
11/09/2019 3:36 PM
Why not just go with liquid nitrogen?...not sure what would happen, but it would be exciting and possibly even epic....In any case would make a good video, you know if they survived...
11/10/2019 4:29 PM
Although liquid nitrogen is much colder than dry ice, it is also very expensive. And it would be much harder to get it in the hole safely than dry ice except maybe where there is a crack in the soil where the smoke is coming out. But then you probably couldn't get as much in as is necessary to stop the fire.
11/09/2019 3:47 AM
Why not put boreholes into the hot coal and pump water down into the hot carbon where it will break down and produce H2 which can be used for the fuel cells.
Remember that in the early days gas works used to treat coke with water to produce water gas a mixture of H2 and CO to be burnt in homes.
Surely these uncontrolled fires could be harnessed to produce energy and even steam with the right sort of piping. The steam could be used for LP turbine to generate electricity.
Hare today, goon tomorrow!
11/09/2019 4:22 AM
Any sort of generation requires a controlled source of energy...not to mention the fire is constantly moving and the environment is extremely toxic...
11/09/2019 11:42 AM
11/09/2019 12:05 PM
You would think the military would have a special unit for fighting these fires as they are a threat to people....they certainly have enough money...
https://www.nad.usace.army.mil/About/Regional-Centers-of-Expertise/Fire-Protection/
Contracts For Nov. 8, 2019
https://www.defense.gov/Newsroom/Contracts/Contract/Article/2012852//
https://www.defense.gov/Newsroom/News/Article/Article/1594592/army-engineers-to-battle-western-wildfires/
11/09/2019 12:45 PM
sfgate.com/bayarea/article/Mysterious-underground-fire-Yosemite-Stanislaus-14428686.php
The term "controlled burn" is an oxymoron. Some other examples: "old babe", "working vacation", "resident alien", "clearly misunderstood" and "military intelligence"
11/09/2019 3:16 PM
No I believe there are valid examples of all of those terms...
11/09/2019 3:36 PM
Another state added to the list. This may be a common start of wildfires.
sltrib.com/news/environment/2019/06/21/coal-waste-piles-still/
11/10/2019 11:22 PM
..."While the uncontrolled burning of coal may seem alarming, this scenario is neither uncommon nor does it pose an immediate threat to the environment or public safety, according to Darren Olsen, a district ranger on the Manti-La Sal National Forest."...
Wait what? Why is this source of CO2 of no concern? ...and every other source is...? Not to mention the other toxic byproducts....all of which seem to be a threat...
We could cut our CO2 emissions by 20% just be extinguishing these fires...
11/11/2019 12:23 AM
Yes, and I think that should be the top priority for any money going to combat climate change. As time goes on, more fires are going and few if any are put out. That means that this is contributing exponentially to the total.
11/11/2019 3:29 AM
I agree...start immediately...
11/11/2019 4:52 PM
Why not drill and inject water to harvest in-situ geothermal energy from the fires?
Eventually you put it out, but in the meantime you generate some cash.
11/11/2019 10:15 PM
See #11
11/12/2019 11:24 AM
So you're telling me that you couldn't find the leading edge, drill and get some heat out of it?
Do we actually have any engineers here?
11/11/2019 11:27 PM
No, I don't think that will put it out. It keeps spreading out on the edges. You would have to have a pipe coming out with the hot water to harvest any heat. Your pipes would be in the middle to be at the hottest spot, but that spot keeps changing.
11/11/2019 11:34 PM
"On the face of it, this is not a volcano in the TransBaikal region of southern Siberia, but it has many similarities. The ground is hot to the touch..."
http://siberiantimes.com/science/casestudy/features/f0203-is-this-an-ancient-natural-pyre-where-underground-fires-have-raged-for-thousands-of-years/
This is a case where there is lots of ice around to use to put in the hole.
11/12/2019 11:44 AM
I don't think you realize the scope of the cavernous holes you are suggesting to fill, and the amount of water you would need...
You would have to pump half the ocean down there....then again it may solve the sea level rise issue....
11/12/2019 4:20 PM
In the case of the picture above, you just need Big Bad John to rip out the beams.
11/12/2019 5:01 PM
In the thick toxic gas and smoke so dense you could cut it with a knife, and temperatures in the hundreds, I'm afraid anybody entering would be something akin to a volcano sacrifice....
11/12/2019 9:40 PM
Use gas masks or send a robot in with a rope. Or one artillery shell should do it.
11/13/2019 12:32 AM
Now we're getting someplace....
Register to Reply 37 comments
Jpfalt (2); Rixter (1); SolarEagle (15); StandardsGuy (16); Stef (1); Tornado (2)
