Previous in Forum: Material testing Instrument   Next in Forum: controllers
Butadiene Level Transmitter leg filled with NMP
10/24/2007 12:18 AM
While measuring butadiene level in a vessel, the the transmitter legs are filled with solvent NMP( N-methylpyrrolidene). Density of NMP is 1.03 gm/CC while that of Butadiene is 0.638 gm/cc.
My question is , will it affect the level measurement accuracy.
Pathfinder Tags: Butadine level measurement
Re: Butadiene Level Transmitter leg filled with NMP
10/24/2007 4:02 AM
What sort of transmitter? Pressure? Differential pressure?
What are the heights of the legs compared to the level in the vessel?
10/24/2007 11:10 PM
Difference in density must be taken into account mathmatically when working on the differnce in hieght. As long as this is done accuracy should not be a problem. Other than that fill your legs with Butadiene the same as in the vessel then SG is not relivent.
I attend work so my dogs can have the good life.
Register to Reply 2 comments
