Previous in Forum: How To Seal 3 Phase Motors From Water Intrusion?   Next in Forum: earthing
Electrical engineering - copper busbars
10/24/2007 9:26 AM
what is current carring capacity in copper busbars?.
2.24 mm wire equivalent wire in sqmm
manimuthu
India - Member - Electrical Energy
Re: Electrical engineering - copper busbars
10/24/2007 11:13 AM
I thing you required the current rating for 2.5sq.mm copper wire. This rating will be
18amps only.Any other things reply please.
10/24/2007 11:18 AM
In domestic electrical wiring, 2.5mm2 solid-conductor twin-and-earth cable is commonly used in domestic ring-main circuits that are rated up to the capacity of a 32A breaker and in spurs off the ring. If a circuit is wired in 2.5mm2 as a radial then the breaker must be down-graded to 20A.
10/26/2007 4:10 AM
Current carrying capacity of busbar depends on the corss section area. Please refer to NEC for current density of busbar..1000amps/in2 or 1.55amps /mm2
Register to Reply 3 comments
G.Swaminathan (1); popoy12345 (1); PWSlack (1)
