Previous in Forum: Quantum Theory   Next in Forum: Ethernet: Collision domain of a Network Hub...(What Does this Mean?)
"No Disk" Error For Audio CD's
10/25/2007 1:41 AM
Why does the JVC audio cd unit now 7 years old display "No disk" at times and at times plays the same cd without problems.
I tried a cd cleaner, it does not help.
I would like to know if there is an electronic sensor which need to be replaced.
Australia - Member - New Member Popular Science - Cosmology - New Member Hobbies - Fishing - New Member
Re: Audio cd
10/25/2007 5:11 AM
I'm not an expert but you may just have dust affecting the laser scanner. Clean that.
If you don't laugh, you cry.
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: "No Disk" Error For Audio CD's
10/25/2007 10:09 AM
I don't think those cleaners do much good. I usually clean the laser lens with a cotton swap and alcohol (very carefully). The lenses are not always easy to get to, especially on multi-disc units. If cleaning the optics doesn't help, it may just be that the laser is getting weak. As the laser diode ages, it's output drops, and errors will result. The only fix for this is a new laser pickup assembly. I have replaced a few (around $30/US), but most times, it's not worth it due to the age of the unit.
Tom
10/26/2007 12:19 AM
I've come to regard all playback devices (CD players, DVD players, VHS players, Betamax players, and so on) as essentially Kleenex. Speedo Credo method - dump everything onto a big HDD on your computer, and back it up from time to time. You'll lose some fidelity using MP# format, but most folks wouldn't notice. Audiophile method - Reel to reel, or, believe it or not, HiFi Beta. Much time and trouble, but better audio quality, and the equipment is hell for strong and cheap now too.
If all else fails, read the directions. That's if, and only if.
10/26/2007 10:27 AM
Just dump the 7 years old ancient technology and buy a new one for another 7 years of confident and worry free operation. Laser kit for 35 dollars and I do not think every one can do by himself.
Regards;
Nadeem
May God keep y'all in his blessings Nadeem Butt
10/26/2007 4:03 PM
It is ill and on its death bed. probably descard it and go for a newer , far better , DVD , BLUE RAY , MPEG3/4 technolgies . 7 years is a ancient technology its impractical to change the lens sensor assembley and mechanism , it won`t do any good for long run , also original components are things of past
10/29/2007 2:45 AM
Thanks to all commentators.
I tried the cotton swab and lens solvent, but it still the "no disk" message.
If I am sure the lens is the problem I might try replacing it. it appears reasonably accessible.
I think its time to take up the suggestion of putting everything on a hard disk and move up the tech ladder.
RAF
10/30/2007 3:35 AM
The first thing we do is to check the power supply- there are many electros which degrade- we have test instruments- after this, there could be fault in control pcb- servo i.c.- there could be slipping load belt- there could be faulty limit/load switch- after all this, there could be faulty spin motor- or faulty optical block- there is an adjustment on the ob to increase laser (mark- increase- try)- no good?- without tester to measure laser output, it is safe to consider laser u/s- if can obtain cheap r/p do so- really these things are so unreliable for this reason!. Remember record players?- anyone could change the stylus, & they lasted for ever!.
Register to Reply 7 comments
geomech (1); ktel60 (1); Nadeem0430 (1); Neil Kwyrer (1); RAF (1); tdesmit (1); vikas (1)
