Previous in Forum: "No Disk" Error For Audio CD's   Next in Forum: Samsung DVD Decorder
Ethernet: Collision domain of a Network Hub...(What Does this Mean?)
10/29/2007 1:27 AM
(1)Ethernet is based on CSMA/CD and collisions are an integral part of the
protocol. Clearly explain the following statement.
"Collision domain of a Network Hub is all ports of the hub whereas Collision domain of Network Switch is a single port".
Re: Ethernet
10/29/2007 12:27 PM
Any message recieved on a hub gets transmitted out on all ports (therefore: Collision domain of a Network Hub is ALL ports of the hub). A switch has the brains to take an incoming message and route it to ONLY the specific port that has the destination IP connected to it (therefore: Collision domain of Network Switch is a SINGLE port).
Re: Ethernet: Collision domain of a Network Hub...(What Does this Mean?)
10/30/2007 12:25 PM
A hub is nothing more than a joining of all the cables from all the ethernet devices which are connected on that section of the network.In other words it cannot differentiate the signals going to any particular computyer.
A switch on the other hand creates "small sub-networks " based on the IP addresses on the message.
In this way when the header frame is sent ahead of the message, the switch quickly reads the destination addresses and creates a virtual private connection between the two devices so the collision domain is reduced.
Learn more, Do more , Be more
