Typically, you would control the power supply that is creating the 16kV, in stead of trying to control/switch the 16kV. A suitable supply for the application would have a way to disable the high-voltage output, as well as control the output power/current. Please make sure you know what you are doing before playing with high-voltage and high power lasers, or you might get a surprise.
we are working on that machine's service, and we wanna produce our own laser machine, firstly high voltage like 16kv is used in the CO2 laser machines. so the 16kv(DC) can be provided. they can control the current in the 16kv(DC) with power tetrodes( COVIMAG ). but there are some other methods and i would like to know how can i do it, if you need for answer i can send you some schemas for this application.
My comments were based on my knowledge of electronics, my experience with laser circuitry is very limited. It appears there are others here that are certainly more experienced in lasers, hopefully they can get you headed in the right direction.
the input of transformer is 380V 45A, the output is 16kv and 72ma, after that we convert this voltage DC, i wanna create a pulsed voltage, how can i switch on and switch off this voltage in safety
