I have an air-cooled exchanger that doesn't perform well in the summer months and hasn't performed well for years. The fins on the tubes are L-Footed style fins which API says shouldn't be used for temperatures above 270 °F. I have measured amps going to the fans (they are fully loaded), the blade pitch on the fans is at maximum, corrosion does not seem to be a big factor, the process conditions and atmospheric conditions are basically at design. Typical operating temp on the inlet is 255 °F and outlet temp is 150 °F by design but > 180 °F in operation.
The only thing that I can find that might be a problem is that during shut down and start up of the facility, an upstream exchanger has no cooling flow going to it so the inlet temperature of the process going to the air-cooled exchanger can rise to 440 °F for up to 10 hours at a time. My data historian is only 1.7 years old so I only have that much data (exchanger has been in service for 10 years) but this has happened 6 times during the last 1.7 years.
Obviously this is above the fin's design temperature so I am hypothesizing that these high temperature excursions are causing the fins to separate from the tube wall, causing a permanent loss of heat transfer area. Does anyone have experience with these fin types that could tell me whether or not this failure mode is probable?
