Previous in Forum: Assist HS Student with Circuit Board Layout Engineering?   Next in Forum: Calculate the Velocity of Gas
Range and Approach for Evaporative Condenser
01/20/2020 5:38 AM
Hi,
Could anybody help me with the formulas to calculate "Range" and "Approach" of an Evaporative Condenser.
For eg. if the Evaporative Condenser is Ammonia based refrigerant, would it play a role in the formula?
Are the calculations same as we calculate Range and Approach of a Cooling Tower, based upon water in and out temp, air wbt etc. ?
Thanks
Re: Range and Approach for Evaporative Condenser
01/20/2020 5:50 AM
The driving force that provides the heat transfer performance is usually taken as the log-mean temperature difference across it.
The choice of <...Ammonia...> has an impact on the choice of wetted materials. The evaporation temperature of the <...Ammonia...> is determined by the pressure at which that side of the <...Evaporative Condenser...> operates.
<...anybody help...>
Heat transfer has been studied extensively; try Perry, "The Chemical Engineer's Handbook", any edition.
01/20/2020 7:34 AM
For a <...Cooling Tower...>, as opposed to an <...Evaporative Condenser...>, the two fluids are not separated by any solid surface, so the performance of a cooling tower is determined by the wet-bulb temperature ["wbt"] of the air passing through it; no evaporative cooling tower can cool the water passing through it to a lower temperature than this despite the ambitions of junior Process Engineers in the summer months.
01/20/2020 9:38 PM
01/21/2020 12:08 AM
Hi maverick
I am a little confused as there seems to be some difference from the way I would usually use these terms (and a common problem is that terms are often used interchangeably in different industries and countries)
My background is oil & gas and the utility systems that go with them
Range in particular is something that I would normally only use on a cooling tower.
In that case Range = Inlet Hot Cooling Water - Outlet Cooling Water
Clearly this could be used in any exchanger.
For a cooling tower Approach = Ambient Wet Bulb - Cold Cooling Water Out
The problem with asking for calculations is that we do not know what information you have; what you need and what your objectives are.
In most of the projects on which I have worked the range = 10C (18F). For systems where river / sea water is used this is based on limits for the returning stream. So normally this is defined for the process.
Approach typically varies depending on the type of heat exchanger. Normally as the approach narrows the heat transfer area increases. In a cooling tower a close approach is desirable to give the lowest possible cooling water temperature.
You mention an evaporative condenser with ammonia.
So I think this means you have cold ammonia vaporizing on one side and a process stream condensing on the other.
On the ammonia side the range would be a notional 0C - with pure ammonia at an approximately constant pressure vaporization takes place at a constant temperature.
On the process side the range depends on the composition of the stream. The purer the stream the narrower the range.
For the approach it depends on various issues. but typically for different types of exchanger the practical limits can b anything from 2-3C (plate exchangers) to 15-20C (Air Coolers).
Some more information would enable us to help you better
eg on range you can either fix range to determine flow or fix flow and determine range where
Duty = flow of coolant * range (not quite that simple if you have vaporisation but basically thats how it goes)
Approach is less of an issue with an ammonia cold side as you can vary the ammonia pressure to adjust the temperature and so widen the approach with your process side and not end up with huge areas.
For a cooling tower the wet bulb temp cannot be changed (although it will vary through the year)
In this case the closer the approach the larger the tower
Register to Reply 4 comments
PWSlack (2); simonsd (1); SolarEagle (1)
