Previous in Forum: Diode Parallel to a DC Contactor   Next in Forum: Old Markon Generator Trouble
23 comments
Cause of Solder Cracks?
01/27/2020 12:27 AM
My boiler for our home hydronic heating system stopped working. The cause was cracks in the solder connections on the Molex socket pins, on the Honeywell auqustat circuit board. The HVAC contractor that installed the furnace a little over ten years ago said intermittent connections was a common problem with these aquastats.
I contacted Honeywell Home and Building Control Customer Relations for Contractors. They said they could find no notices of engineering changes resulting from cracked solder connections. They said therefore, this type of failure would be rare and not common. I pointed out that I did not believe HAVC repairmen would disassemble bad auqustats to determine what had failed internally, and then report it to Honeywell. As far as I know, they just replace the bad part. Honeywell then pointed out that my auqustat was way beyond its warrenty, and ten years was a good service life for this part.
I believe the auqastat failed do to a manufacturing problem. All five pins on the Molex socket had cracked solder joints. Force necessary to plug or unplug the connector was minimal. I think the socket was soldered first and then the hold down screws were put in, instead of vice versa. Possibly there was a slight gap between the socket and printed circuit board, caused by an improper insertion, or by the soldering process itself. Securing the plug shell with screws after soldering, plus thermal cycling of the boiler, would then apply high force to the pin solder joints, causing them to crack over time.
My questions are:
1. What is your experience/opinions on why all the Molex solder connections cracked?
2. What is your experience with causes of auqustat failures?
3. Is ten years a good service life for an aquastat used on a home boiler?
Re: Cause of solder cracks?
01/27/2020 12:43 AM
..."Solder cracks occur mainly because of thermal fatigue due to thermal shock or temperature cycles or the use of lead-free solder, which is hard and fragile. Solder cracks on MLCCs developed from severe usage conditions after going on the market and during manufacturing processes such as soldering."...
https://www.mouser.com/pdfDocs/mlccsoldercrackcountermeasuressolutionguide.pdf
The do-gooders strike again....
01/27/2020 6:09 AM
I agree that this is likely a thermal fatigue problem of lead-free solder. With this failure happening after the expected lifetime (warranty) of the product there are probably other parts close to failure, too.
01/30/2020 8:12 AM
issue is totally the lead-free solder period. good call eagle guy.
01/27/2020 4:45 AM
I would tin the tip of a small iron and touch each of those bad joints for a second.
I would never ever expect that to happen to all the solder connections.
Honeywell can keep their crap if they think after 10 or less years it can fail miserably? What if the entire home was held to that weak standard?
Unbelievable.
That's type of failure should really be impossible.
Imo
01/27/2020 6:32 AM
The Printed Wiring Board (PWB) that you show was "wave soldered" with the components in place and then as you describe, the screws were fitted in what was probably an incorrect and unnecessary assembly step.
The images of the failed joints could be indicative of a variety of design, fabrication or end use situations that led to the outcome. If fitting the screws did not cause the problem straight away, then that is probably not the cause.
More likely it is that someone applied additional force to the connector, pushing or wiggling the mating part harder that sheared the soldered joints.
I tend to feel though that the preheat time for the flow solder process was a little short/cool, since the lead at the RHS of image shows poor wetting of the single conductor (Component F1) with a concave hollow in the shadow of the lead and the multistrand wire (Orange) to the LHS also seems to show an incomplete wetting of the wire/solder interface. Thus it is possible that the Molex terminals were only wetted at the solder interface and not for the complete through hole connection on the PWB, but cannot confirm since the connector obstructs the view on the component side of the board.
Lifecycle and durability expectations for PWBs in service (10 years ago) were classified by their service expectations and criticality. Heating controls, light dimmers and other convenience items were only just better than toys and greeting card inserts. Safety items like electric brakes in cars got a higher expectation while aircraft operational circuits got an even higher expectation.
Considering that most cars (10 years ago) only ever offered 5 year warranty, you have probably done "OK" on this item.
As others have indicated, it would seem "repairable" and unless the PWB is specifically identified as ROHS Pb free, then it was probably made using normal solder and for its current function, the concerns with mixing lead free and leaded solder in this application is relatively low risk.
01/27/2020 7:15 AM
I have seen the same type of problems in a Trane Evaporator timer relay.
It was mounted in a location that protected it from extreme thermal cycling.
The bad solder joint appeared to have been in motion before it completely cooled;it had a cloudy appearance.
I repaired the relay by simply re soldering the joint,and all of the others on the board also.
I thoroughly removed all flux and coated the joints with urethane paint.Several layers of clear fingernail polish will work well if nothing else is available.
Factory coating is multi-layers .The first layer,next to the board,is a moisture barrier.The 2nd layer is a de-ionizing layer,to make any water non conductive,the final layer is another layer moisture barrier.
Cannot duplicate this process very easily,but I have had good results with urethane or lacquer.
I have seen control modules in vehicle fail from thermal cycling after about 10 years or so,but the appearance of the joint is is different.
Here is a link to the reasons for solder joint failure.
https://www.ansys.com/blog/top-5-reasons-solder-joint-failure
Re: Cause of Solder Cracks?
01/27/2020 8:04 AM
I'd suck out the existing solder; tighten the screws, then, re-solder the joints.
Ten years seems like much too short a service life for this sort of thing.
I agree with your belief that the joints were soldered before the screws were inserted. It would take several years for the mechanical damage to manifest as an electrical failure.
01/27/2020 12:06 PM
I had an identical failure on a windshield wiper control PCB.
The failure in the lead free solder joints was due to vibration created by a mechanical relay.
Just clean off any conformal coating, remove the existing solder, and replace with 60/40 and that circuit board will outlive the boiler.
MikeMack747
Good Answers: 804
01/27/2020 4:50 PM
I had a similar failure on a PCB for my washer. I bought a rebuilt board and installed it, but I did my own forensic analysis on the one I removed, found the exact same thing and touched up the solder points with an iron, tested it and it worked fine, so I have it as a spare now. On reading up on it, I found that this is becoming more common all the time, ever since the RoHS issue of removing lead from solder and the PCB traces. My theory is that despite YEARS of advanced warning of the RoHS changes, a lot of low-end mfrs just switched to lead-free solder and flux, without thinking through ALL of the other engineering consequences such as brittleness of the new joints.
01/27/2020 11:29 PM
In agreement with many others, the lead-free solders have caused a LOT of problems.
In my experience, the lead in solder problem has been greatly over-exaggerated. I have literally been soldering with leaded solder for 70 years. I only have two hands, so a lot of the time, I had (still have) the soldering pencil or gun in one hand, one or more parts in the other, and the (nearly always 60/40) solder in my mouth.
Whenever I repair any electrical device, which is a frequent occurrence, I nearly always use 60/40.
01/28/2020 12:28 AM
The joints shown were probably never done right. I have electronic equipment more than 50 years old. None of them has solder joints any where close to what is shown. A joint will stay looking new except if subjected to severe mechanical or thermal stress.
01/28/2020 12:45 AM
Sure! 50-year-old electronics were soldered with lead-bearing solder, most likely 60/40. It could flex much more easily, so didn't crack nearly as easily.
01/28/2020 12:41 AM
From my experience this is likely to have been a manufacturing problem caused by the reflow solder technique when the solder is not hot enough and has not adhered to the pins correctly. Too cold a solder joint will have a grey colour.
What to do, that is easy if you are handy with a temperature controlled soldering iron all that is required is to heat and manually solder all the joints on the board with a good 60/40 solder. It is even better to use a solder sucker to remove the old solder and redo the joint. I have fixed many a poor quality soldered board on plasma cutters, welders, inverters etc.
The lead free solder seems to be prone to this problem. I had to fix a lot of boards on a well known USA brand of wire feeder and 3 phase welding machines, (just out of warranty, surprise)!
Hare today, goon tomorrow!
01/28/2020 9:15 PM
If you check the photo you will see the solder is well connected to the pin.I would suspect that the problem initially has been caused by an over enthusiastic tech and over time it has degraded to a total failure.
Molex sockets are a bit stiff to assemble and disassemble, you would have noticed this in your work repairing welding equipment.
01/29/2020 5:23 AM
"It is even better to use a solder sucker to remove the old solder and redo the joint."
In this case where it is clear that the pins were not fully inserted before the flow soldering, it is important to: remove the old solder; remove the socket; clear any other solder from the area to allow the socket to be fully re-inserted; re-insert the socket; tighten the screws, then, re-solder the joints.
If the mechanical joint is not sound all the forces are on the solder joints.
Unfortunately it will probably be quite difficult to remove the socket, because of the solder between the socket body and the board, but, it's well worth the effort. Sometimes you have to keep: "sucking; adding fresh solder, and, re-sucking".
01/30/2020 8:49 AM
If you have compressed air in your shop,I have found that wearing a mask and heating the joints separately and hitting with a blast of compressed air will completely clean the joint and thru-the board ferrule.
This is very effective when de-soldering multiple-pin elements.Very good results for me.
I am not sure if the canned air products have enough pressure or volume to do this,but you could try it.
01/28/2020 12:42 AM
In my experience with a situation somewhat like yours, a solder crack issue was caused by vibration over time and I believe not enough solder was applied to the solder joints.
01/28/2020 7:49 AM
Here is a link that explains the characteristics of lead/tin alloys and how the ratios affect the finished solder joint.
https://ae5x.blogspot.com/2019/12/eutectic-or-non-eutectic-solder-does-it.html
01/28/2020 7:58 AM
The main point of failure with thru-the-hole soldering has always been the hole site.
That is one of the reasons manufacturers went to surface mount,(as well as faster automated production).
A solder joint is not a good mechanical joint.
Mechanical stability must be achieved before soldering.
A lot of thru-the-hole components are not properly anchored before soldering.
This is especially important in high vibration applications.
Even surface mount components will have issues with vibration.
Most automotive,and especially aviation, electronics are now potted in solid with epoxy or a silicon gel that absorbs vibrations,or both.
Relatively small runs of electronics still use thru-the-hole components.
01/29/2020 10:30 PM
I would be interested to know what the pins are made of.
I am with SolarEagle on this, thermal cycling and lead-free solder are most likely the problem. If the pins are from a high expansion alloy, this will exacerbate the problem.
I expect these sort of failures are going to become more prominent as all the lead-free products age.
South Africa - Member - Member Shonver
01/30/2020 1:55 AM
I have seen similar joint failures on wave-soldered boards. Usually, the affected components were not under stress. In this case, it seems that the only component affected is the one under stress (the hold-down screws), so I concur with your initial impression that the wrong assembly sequence was employed.
DON'T PANIC
01/30/2020 7:18 AM
Have had similar problems with Molex connectors on 2 way radio boards led free does not help but 60/40 did it as well, we were looked at thermal cycling,. tried silicon encapsulating socket will have to wait for MTBF to come up.
We did remove clean & re solder with 60/40 our sockets have no hold down screws though so think your problem could be not seated correctly, screws not fitted before solder or over tightened after.
01/30/2020 7:53 AM
It seems many of the observations have identified various possibilities of the failure in an effort to find the root cause. The product is over ten years old so the question becomes can this be reworked or repaired, to which there have been many suggestions leading to a positive outcome. Understanding and identifying the cause of the failure should lead to better manufacturing going forward. The one thing I could add regarding the process and sequencing is, was the mechanical connection properly specified. Applying a wrong torque can easily cause failure as it creates stress in the component and PWB. There are many ways to pursue if Honeywell was aware of the problem but as it is not a 20,000 foot issue hardly worth the effort.
the light is much better over here
Register to Reply 23 comments
d_rutchik (1); dkwarner (2); garth (1); GJM (1); HiTekRedNek (4); JE in Chicago (1); JRaef (1); Just an Engineer (1); MikeMack747 (1); radman (1); Randall (2); redfred (1); setlock77 (1); Shonver (1); SolarEagle (1); StandardsGuy (1); Stef (1); WCart (1)
