Previous in Forum: why disc brake on rear wheel?   Next in Forum: Motion transmission
8 comments
displacement of gear pump
10/27/2007 2:59 AM
how can i find the displacement of a gear pump using the parameter of the gear it self? can anyone tell me the equation?thank you ...
Good Answers: 266
Re: displacement of gear pump
10/27/2007 7:40 AM
The volume between two teeth of the driven gear times the number of teeth on the driven geat times RPM times two.
10/27/2007 11:57 PM
Interesting.
How to find the volume between two teeth, using parameters like, 'root dia, tip dia, number of teeth etc'? Any empirical ratio available?
10/28/2007 3:10 AM
Use the polar integration method on the tooth evolvent profile
Kind Regards, Randolph Toom - www.heat2power.net
10/28/2007 4:23 AM
How about the leakage? These pumps I thought were incredibly inefficient or am I wrong? Maybe with modern techologies ok, my memory on them is at least 25 years old.
I thought that is why they invented vector pumps, they don't leak and are very precisly dosed.
10/28/2007 6:15 AM
External gearpumps are used also in todays hydraulic systems up to 200 Bars
The housing in de gearpump is hydraulical ballanced so the sides off the gear has a minimal lekkage.
Averidge efficiency 80-90 Percent.
Gearpump Volumetric efficiency 85 up to 96%
Vanepump Volumetric efficiency 85 up to 93%
Pistonpump Volumetric efficiency 95 up to 98%
The lekkage in a gearpump is depending on the tolerances in the pump and so the costs off the pump. Often we measure 98 Percent flow off the theroretical flow @ 75% off the maximum allowed pressure with 2000-3000 raves
Older pumps will be changed out with 15 % leakage
Depending on Brand. Displacement(V)= Flowrate X 100 / revolutions X efficiency
Br, Harmen Beskers
Engineering Fields - Automotive Engineering - New Member APIX Pilot Plant Design Project - Member - New Member
10/29/2007 9:18 AM
most are closed looped for accuracy if required - ie.. flow meter feeds back to a frequency drive on the motor to adjust the rpm and correct the flow
Duct tape is like 'The Force'. It has a light side and a dark side and holds the world together.
10/28/2007 1:26 PM
could you pls tell me what is a vector pump..and what ensures that they dont leak....thx
10/28/2007 3:23 PM
gear ratio ! from that you can find displacement given by the manufacturer
Register to Reply 8 comments
Anonymous Poster (1); case491 (1); cbs (1); jooka (1); ozzb (1); Randolph Toom (1); vikas (1); yesyen (1)
