Previous in Forum: about steel   Next in Forum: engine and shaft alignment
this is regarding heat loss
10/27/2007 11:10 AM
calculation of heat loss through 350mm wall thick cermic fibre modules.
Good Answers: 19
Re: this is regarding heat loss
10/27/2007 12:18 PM
Learn to add details to your question. Whats delta T? Where are you installing in?
Ambient temp? Which make?
If you are already using/ deciding to use, the product carries a detailed spec. sheet indicating graph the heat losses, learn to go through these first.
10/28/2007 7:10 AM
the ambient temp outside the wall is 40degree celsious and inside the wall is 1250 to 1300 degree. I am talking about strip cleaning furnace in galvanizing line.I am doing some study on energy saving in furnaces. so i would like to know about the same.
Good Answers: 19
10/28/2007 9:19 AM
Your Insulation Material - You really have to check the spec.sheets of different suppliers.
Normally Rock wool high temperature & density are utilized and cladded with 24 swg. Galvanized Sheets .
The rule of thumb for Insulation is, "if you can keep the palm of your hand and comfortably stand" - thats 90% good insulation.
For energy conservation of furnaces :
1 . Modulating Air / Gas Ratio Burners.
2 . Pre-heating Combustion Air with Recuperators.
3 . Good Insulation.
4 . Balanced Zero furnace pressure.
Not +ve else hot air will blow out. Not -Ve else cold air will be sucked in.
5 . No cracks/openings at doors & joints.
6 . Monthly Flue Gas Analysis & Burner Tuning as required.
7 . Gas Flow & Temperature hourly Strip/Circular Chart Recording.
8 . Air pressure switches on all Blowers.
Further details: NAMCO HandBook.
10/28/2007 2:22 PM
You can conduct studies on the same through stimulation programs , energy saving is itself big topic
10/29/2007 1:32 AM
Dear Vijay
Checkout this website and down load the course ware of Energy auditors/Managers http://www.energymanagertraining.com/new_index.php.There is a chapter on Furnaces.
THE ENGINEERS MOVE THE WORLD,IDEAS RULE THE WORLD
ducon (2); KOTIAN (1); vijay_pawar28 (1); vikas (1)
