Previous in Forum: Thesis for Final Year   Next in Forum: Solution for App Start-up
How Do I use correctly Java CSVtoBean
03/25/2020 2:14 PM
I am using Jdeveloper to create a small software which reads Weatherdata from a .csv file and proceses it .
Unfortunatelly i am stuck at the first step, reading data from file . Keep getting back the following Exception : Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/commons/collections4/MultiValuedMap
Please see attached my progress so far , please feel free to edit or comment .
public class Main {
* @param args
@SuppressWarnings({"rawtypes", "unchecked"})
public static void main(String[] args) throws IOException {
String fileName = "C:\\JDeveloper\\mywork\\Csv reading\\Project1\\wdata1.csv";
Path myPath = Paths.get(fileName);
try (BufferedReader br = Files.newBufferedReader(myPath, StandardCharsets.UTF_8)) {
HeaderColumnNameMappingStrategy<Read> strategy = new HeaderColumnNameMappingStrategy<>();
strategy.setType(Read.class);
CsvToBean toBean = new CsvToBeanBuilder(br).withType(Read.class)
.withMappingStrategy(strategy)
.withIgnoreLeadingWhiteSpace(true)
.build();
List<Read> Data = toBean.parse();
Data.forEach(System.out::println);
Also have a different class with the column names :
public class Read {
@CsvBindByName
private String stationid;
@CsvBindByName
private String datestamp;
@CsvBindByName
private double wgust;
@CsvBindByName
private int wdir;
// get, setters here
I have tried to import the neccesary files, tried most of the solution i found, but none of them seems to be working . I am really new to this, i would appreciate all the helps !
The file I am using looks like this :
Pathfinder Tags: "Java" "CSV" "JavaBean"
Re: How Do I use correctly Java CSVtoBean
03/25/2020 2:40 PM
"...a common error in Java which occurs if a ClassLoader is not able to find a particular class in the classpath while trying to load it."
Read more: https://www.java67.com/2012/08/what-is-noclassdeffounderror-in-java.html#ixzz6HjASTXhh
03/26/2020 11:13 AM
Thank you for your anwer managed to read the data in and displayed on screen.
Extended the code with a writer to write it in a .csv file.
My next step would be to calculate date specified averages/min's/max's of the Wind Data.
I have created a scanner to get the min and max date value from the user, but now i am stuck processing the data from the list .
Could you help me out or point me to relevant information ?
Register to Reply 2 comments
