Previous in Forum: Does Ibuprofen Make Covid-19 Symptoms Worse?   Next in Forum: One's Worst Experience is Usually Your Best
11 comments
Application of Rotating Magnetic Fields Against Viruses and Bacteria. Experimental RMF Generator
03/30/2020 8:54 AM
Applications of rotating magnetic fields against viruses and bacteria
Experimental RMF generator
Studies :
https://publiclab.org/wiki/applications-of-rotating-magnetic-fields-biotechnology-rotating-magnetic-fields-rmf-generator-x-device
Studies, results :
"Application of Rotating Magnetic Fields Increase the Activity of Antimicrobials Against Wound Biofilm Pathogens "
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC5760636/
" Physiotherapy with rotating pulse magnetic field in combined therapy of chronic obstructive pulmonary disease "
https://www.ncbi.nlm.nih.gov/pubmed/15759470?log$=activity
" Growth of Plasmodium falciparum in response to a rotating magnetic field " (MALARIA)
https://malariajournal.biomedcentral.com/articles/10.1186/s12936-018-2333-2
ST
Re: Application of Rotating Magnetic Fields Against Viruses and Bacteria. Experimental RMF Generator
03/30/2020 4:16 PM
Interesting. Another way of creating a rotating magnetic field would be to take a shaded pole motor apart and remove the rotor. You are stuck with the line frequency, but the exposure should be quite repeatable.
(For a more uniform field, you might want a multiphase motor.)
03/30/2020 7:29 PM
Maybe if they could spin you around while you are in the MRI machine? That's a real strong field.
03/30/2020 9:49 PM
Those scare the heck out of me since I heard a story about a guy getting killed? Or nearly? By a flying oxygen tank or something in a room where one was turned on.
03/30/2020 11:04 PM
Yeah, that was a freak accident. I've had four or five MRI's for my benign brain tumor. It's a lot more dangerous to drive your car.
04/01/2020 7:38 AM
MRI does not emit the ionizing radiation that is found in x-ray and CT imaging, it does employ a strong magnetic field.
04/01/2020 2:51 PM
. . . and RF pulses.
03/30/2020 11:12 PM
Where do you stick that thing? Looks uncomfortable.
03/31/2020 7:26 AM
" Where do you stick that thing? Looks uncomfortable. "
x device (rmf generator ) is a cheap alternative device for laborator tests + a pwm controller to adjust the speed of the motor with purpose to encurage more researchers for future studies.
The answer is on a metalic arm in the lab conected to a pwm controller to adjust the sppeed of the motor, near human cells, biofilms, rats, Caenorhabditis elegans, etc :)
03/31/2020 7:24 PM
Still looks uncomfortable.
03/31/2020 7:08 AM
x device (rmf generator ) is a cheap device for laborator + a pwm controller to adjust the speed of the motor in lab tests to encurage more researchers for future studies.
the answer is on a metalic arm in the lab. :)
08/17/2020 12:55 PM
look promising , the addition of RMF in combined treatment improves treatment and shortens its duration.
unfortunaly they don.t provide to much details
Register to Reply 11 comments
Brave Sir Robin (3); JE in Chicago (1); Jpfalt (2); Rixter (1); sciencetoolbar (4)
