Previous in Forum: 4-Wire Receptacle Alternative   Next in Forum: Discrete Inputs and Outputs for HVAC system
UV Light Bulb System
04/14/2020 3:58 PM
I am working on polymerizing hydrogels that use a specific wavelength. I am looking for a light box that would polymerize a plate about 14 inches by 7 inches. An LED bulb that is 0.1 inch and 3-5mm would also work. The wavelength I need is 350nm. Any help would be appreciated.
Re: UV Light bulb system
04/14/2020 4:06 PM
04/14/2020 4:49 PM
04/14/2020 4:11 PM
A quick Google search led me to this LED distributor. Their family of 365 nm LED products will likely do the job since they are not purely monochromatic and a lot of energy is still at 350 nm. If you truly require 350 nm ±1 nm then some expensive optics will be needed, too.
04/14/2020 5:13 PM
redfred (1); Rixter (1); SolarEagle (2)
