Previous in Forum: cubic yards measuremnts   Next in Forum: method of curtain grout
Steel Reo sizes
10/30/2007 12:12 AM
does anyone know where i can find a table detailing the 2 sizes of each type of rebar
ie; the therotical diameter of an N24 bar is 24mm, but the actual "as rolled" diameter will be something like 29 or 30mm???
is there a summary sheet i can find?
Re: Steel Reo sizes
10/31/2007 11:59 AM
Not sure if this is what you want -- try Google for more info.
http://www.sizes.com/materls/rebar.htm
Results 1 - 10 of about 82,300 for rebar size chart. (0.23 seconds)
Re: Steel Reo sizes
11/03/2007 12:33 PM
If your asking what i think your asking ... then it would depend on the mill producing the bar. Call them and get specs they should be able to give you +/-.
The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair...Douglas Adams
Re: Steel Reo sizes
11/28/2007 5:11 AM
In the U.S. the ACI (American Concrete Institute) gives the dimension for Imperial and Soft Metric (just a metric name tacked onto an Imperial Barsize). The manual I referenced is the ACI Publication SP-66 (04), which is called the ACI-Detailing Manual-2004. It gives values for both the nominal and actual sizes. See "Supporting Reference Data, Page 169". As a lowly rebar detailer, this type of info is my bread and butter. Certainly countries using hard Metric sizes have similar standards organizations. The CRSI (Concrete Reinforcing Steel) Institute here in the U.S. also provides this information ( I believe it's in the Manual of Standard Practice, a slim and very useful booklet. Sorry I don't know about actual vs nominal rebar dimensions for true metric bar sizes. www.eskimo.com/~bfarwick
Anonymous Poster (1); user-deleted-5 (1); wgh71 (1)
You might be interested in: Rebar, Flaw Detectors, Retaining Walls
