Previous in Forum: Flying Petri Dishes   Next in Forum: Ventilator
9 comments
MHS
04/23/2020 10:14 AM
when engineering a new concept and ore an invention where to go from there? for example
1) air compressor 4000 lpm 30 bar power input 6 KW
2)submarine 45km/ph submerged and 65km/ph on the water
have working prototypes and other inventions. and cant reach the right people ore companies
Re: mhs
04/23/2020 11:13 AM
It's a Sales process, not an Engineering one.
Re: MHS
04/23/2020 11:40 AM
...and it's also commercially sensitive, which is why spreading it around on a global internet Engineering forum is not such a good idea.
Re: MHS
04/24/2020 1:39 AM
...no I did not reserve a mail?
Re: MHS
04/23/2020 5:02 PM
Your craft must be relatively small.
The high-speed type motors (used with a reduction gear in submarines) were rated at 1370 horsepower and ran at 1300 rpm, pulling 2600 amps at 415 volts. (By way of comparison, an automobile starter motor runs on 12 volts at a maximum draw of around 45 amps.)
From FleetSubmarine.com
Good luck.
You'll need some technical literature, backed up with some type of supporting information.
Re: MHS
04/23/2020 10:35 PM
That would be 45 amps running at no load, definitely not when trying to start an internal combustion engine where the stall current is in the range of 200 to 600 or more amps. Maybe the quoted 45 amps is the starting current on an electric start lawn mower.
Hare today, goon tomorrow!
Re: MHS
04/24/2020 1:56 AM
it is not Elektrik it runs on a highly modified dry-sump petrol engine. impeller and water jets are used and it is highly memorable and kango upside down also modified exhaust system so it exhales under pressure
Re: MHS
04/24/2020 4:58 AM
So sell the concept to prospective Customers.
<unsubscribes>
Re: MHS
04/24/2020 6:14 AM
NOW that's easier sed then dune. to get hold of the right person to talk to. is next to impossible
Re: MHS
04/24/2020 2:16 AM
it is in the shape of a manta ray and whys 2.5 ton not electric and with some modifications, it will go faster but at speed, I'm having problems with visibility even in very clear water.
Register to Reply 9 comments
lyn (1); mhs (4); PWSlack (3); Stef (1)
