Previous in Forum: Fiberglass material Properties   Next in Forum: Fiberglass Material Properties
10 comments
Copper Lining of Hot Water Storage Tank
11/01/2007 5:23 AM
Hi,
Anybody from the member who can guide for the Fabrication of copper lining for the hot water storage tank? Or any references in copper lining method Internally. This tank is commonly required in Hotels and Hospitals to avoid corrosion on the tank and will increase the life span of the tank materials.
Thanks
Re: Copper Lining of Hot water storage tank
11/01/2007 7:11 AM
Wouldn't a glassfiber or epoxy coating be a better idea?
Innuendo is not Italian for a suppository.
11/01/2007 9:47 PM
I've seen "stone lined" tanks and plastic lined tanks and of course stainless. I'm thinking if it were remotely a good idea, one of the many manufacturer's would be doing it.
I'm thinking copper's a bad idea because of certain corrosions AND, its possible for a bad reaction from the anode rod.
Unless you're the lead dog on the sled, the view is always the same....
Good Answers: 120
11/02/2007 12:14 AM
I thought most tanks are made of steel with a vitrified glass liner fused to the inside. Usually good for 20 years+
Per Ardua Ad Astra
11/02/2007 2:15 PM
Surely good stainless would be fine on its own, probably more expensive though. I never did understand why they are (still) made of copper anyway, whats the reason?
Re: Copper Lining of Hot Water Storage Tank
11/03/2007 2:28 AM
Gentlemen,
Many thanks for the inputs. However, copper lining requirements most likely falls on these standard requirements as follows:
1. common storage capacity: 4000 liters - 10,000 liters tank capacity
2. range of water temperature: 45 deg C - 80 deg C
3. maximum pressure: 150 PSIG
In some instances, if the heating controls fails, sometimes the water tmeperature reaches to 90 - 95 deg C. And if you have the epoxy lining inside, it might damaged (feel-off) which cause clogging on the pipeline distribution and will cause too much trouble to remove it.
Glass Fiber application is almost applied to smallest tank that use in residential building. Larger tank are mentioned above will be very costly and more investment on the manufacturing side.
Stone lining / or perhaps concrete lining is quite cheaper on the other hand. However, transport problem will be the difficult task as it cannot be avoided the vibration / shaking / impact to other other materials while on installation.
Stainless Steel is excellent. However, it will be quite expensive to the owner.
Galvanized Tanks is acceptable. However, when the water has its poor quality with more TDS. This tank will not last so long. Perhaps less than 5 years it will collapse.
Copper lining hot water tanks survive up to 15-20 years or more with proper maintenance. Copper sheets do not corrode in a domestic water quality
The only damaged i have observed to this tank is that the heating coil inside is leaking (using steam as the source of heating). Where the point of thermal stress to the copper lining occurs. However, this damaged can be easily rapaired on site.
The copper lining thanks are the most commonly used in Hotels & Hospitals in the middle east.
Best regards
Jojie
11/03/2007 3:55 AM
Nobody posted a true answer to "Why do we use copper for such tanks?", more the answers is "We just do!".
Although Stainless might be more expensive, it transports heat significantly SLOWER than copper, so would actually be in comparison, a slightly better insulator in that respect, but no matter how aggressive the water, it should come through still "Stain-less!!"
But what the hell, stay with copper for all I care.......I do not store hot water anyway, its all "on demand" with us in this house!! No bulky hot tank to situate, no bulky cold water storage, no possibility of Legionnaires Disease etc etc etc....I am happy.
11/03/2007 4:42 AM
Although Stainless might be more expensive =
it is very much expensive compare to copper line hot water storage tank. The business owner can not afford the cost in reality. for your residence, maybe you might afford to buy that. However, in residencial use, you might need only maximum of 200 liters tank capacity for your family use, thats it. i dont think any manufacturers of water heaters uses SS sheets on the tank.
I am referring the hotwater storage tanks in a large volume consumption as i mentioned especially for the Hotels and hospitals.
I a modern system design of hot water system, the main distribution lines are contineous circulated to maintain the required hotwater temperature at the nearest outlets of the user especially in hotels and hospitals.
My only concern is that, are you familiar in copper lining method? Thanks anyway.
Jojie
11/08/2007 1:11 AM
Just buy you a commercial grade 80 gallon tank that will meet all requirements!
Do reply I am in need of a laugh!
11/15/2007 2:08 AM
80 gallon capacity is quite small tank which can be buy in a commercial store or distributor. The heating methods will be electric heater, probably single phase voltage.
This tank cannot cope up the consumption of a hotel at 150-250 beds capacity or hospital with 200-250 beds capacity.
Most likely, 2-3 tanks of 6000 liters storage capacity with a source heating is Hotwater or steam.
Copper lining tank specs is most common and cost effective and is availlable in the market and being accepted by Hotels & Hospitals. copper materials do not attack by corrosion as submerged in the water. Scale build-up will be the problem issue only as the water is being heated. However, maintenance sched will resolve the problem on a PMP (Preventive Maintenance Program) of the company itself based on the water quality as supplied.
jojie_oak
11/18/2007 3:25 PM
Capacity is everything!
Check out the following to best meet your requirements!
http://www.saveonhotwater.com/
http://www.hotwater.com/lit/spec/storage/A4023.pdf
http://hansontank.us/waterstoragetanks.html
each one is an idea but cost is also the factor!
Register to Reply 10 comments
Andy Germany (2); Anonymous Poster (1); aurizon (1); Horrible Old Bat (1); jojie_oak (2); Sniccus (1); Thadius (2)
