Previous in Forum: Lead Acid Battery   Next in Forum: Motor testing
slip ring induction motors
11/03/2007 9:55 AM
What is the effect of under loading in the brushs of 3 phase slip ring induction motors?
Pathfinder Tags: slip ring induction motors
Re: slip ring induction motors
11/03/2007 2:06 PM
I think this will lead to a sparking effect.
11/04/2007 6:51 AM
As long as you have rated voltage the machine can operate comfortably at no load or anything between no load and full load. What is your application?
11/05/2007 8:30 AM
The m/c is running at full voltage but we have a problem of high wear rate for the brushes.
Do you have any explanation for this phenomena ?
thanks.
11/05/2007 3:04 PM
If by underloading, you mean pressure applied to hold the brushes on the slip rings, I would imagine it would allow the motor to slip. My experience with wound-rotor motors included those with resistors and saturable reactors wired to the armature (via slip rings) for speed control. If one of the brushes loses contact with the slip ring, the secondary will single phase, lose torque, and slip.
Eschew obfuscation.
11/06/2007 4:28 AM
I mean by underloading the current and power of the motor for example if the rated power is 1.8 MW and the actual load is 1 MW What is the result of this phenomena on brushes ?
Also is there a relation between the type of slip ring and the wear rate of the brushes ?
Thanks
Abdallah Zaghloul (2); Anonymous Poster (1); eefourn6 (1); Kyoto (1)
You might be interested in: Slip Rings, Metal Ring Seals, Induction Heaters
