Previous in Forum: Alternative to R123 Refrigerant in Chillers   Next in Forum: Screw Feeder (Auger) Calculation for Variable Flow Rate with Single Screw
ID Fan Design Calculations- Equations
07/16/2020 7:43 AM
I want to know how increasing the size of an ID fan casing ( Centrifugal) effect the performance of the fan. What equations are applicable in this case to calculate the parameters( volumetric flow rate, etc)
Re: ID fan Design Calculations- Equations
07/16/2020 8:52 AM
Re: ID Fan Design Calculations- Equations
07/16/2020 10:25 AM
Perry: "The Chemical Engineer's Handbook", any edition.
07/16/2020 2:02 PM
Effect of axial gap between inlet nozzle and impeller on efficiency and flow pattern in centrifugal fans, numerical and experimental analysis
https://www.sciencedirect.com/science/article/pii/S2214157X13000063
The 'sweet spot' is when the inlet diameter of the housing matches the inner diameter of the impeller....
07/17/2020 11:34 AM
Depending on just what you are doing with the casing, it could end up being similar to reducing the rotor diameter. This is not a typical design modification for a fan as it would be for a centrifugal pump.
PWSlack (1); Rixter (1); rwilliams (1); SolarEagle (1)
