Previous in Forum: threaded joint   Next in Forum: Cast-Iron Hot Water Radiators: Volume and Ratio
Meshing
11/05/2007 4:59 AM
I have built up a composite layer set (real constant 1) it is called, it consists of 4 materials. I am attempting to apply it with a mesh using the shell 99 linear element type.
When I attempt to mesh an area using the "mesh tool" I have an option "area attributes" where i can choose the material number, the element number and the real constant set number.
This is where i am confused, Why do i have to choose a material number and also a real constant set number. All i want to choose is a real constant set number as this will contain 4 materials (the composite), and I should not have to also specify one material number as i have already specified my materials in the real constant set?? this is a contradiction!
Re: Ansys Question regarding meshing
11/05/2007 5:06 AM
I am using Ansys v11 classic
Reply to Forum Thread
