Previous in Forum: Meshing   Next in Forum: Stainless Steel Tube with a Square Cross-Section
Cast-Iron Hot Water Radiators: Volume and Ratio
11/05/2007 12:59 PM
Who has a Table of Water Volume for Hotwater Cast Iron Radiators? If no table is available what Rule-of-Thumb is used in the Plumbing Industry to estimate Water Volume in these Radiators ( Radiator Type & Form included)? Also, what is the ratio of anti-freeze to water in these units for freeze protection (Factored for various temperatures)?
Re: Cast Iron Hot Water Radiator Water Volume
11/05/2007 11:31 PM
"Who has a Table of Water Volume for Hotwater Cast Iron Radiators? If no table is available what Rule-of-Thumb is used in the Plumbing Industry to estimate Water Volume in these Radiators ( Radiator Type & Form included)?"
Consult the radiator manufacturer(s) or fill the system metering the input volume as you will need the total volume to determine the amount of anti-freeze needed.
"Also, what is the ratio of anti-freeze to water in these units for freeze protection (Factored for various temperatures)?"
Every jug of anti-freeze has a table of percent of product required for protection to a list of temperature. You will then have to calculate the amount to add and remove that much water to make room for the anti-freeze.
11/06/2007 6:23 AM
  1. Weigh it empty.
  2. Weigh it full.
  3. Calculate the difference.
  4. Divide the difference by the density of water at the measuring temperature.
If a frost thermostat is placed in the loft-space of the home and set to close the contact below, say, 2degC, and wired to over-ride the system programmer, then no antifreeze is required. A combination corrosion inhibitor and antiscalant additive is a good idea, however.
Re: Cast-Iron Hot Water Radiators: Volume and Ratio
11/06/2007 2:31 PM
my answer may seem to simple or I don't understand the question.
why not fill the radiator with water, then drain into a container and measure the weight or volume?
Kenn
11/06/2007 3:59 PM
"why not fill the radiator with water, then drain into a container and measure the weight or volume?"
Do Nothing Simply when it can be made Complex & Wonderful
11/08/2007 1:01 AM
I would keep this one simple stupid "figure of speech of course" and consider that a gallon of antifreeze will safely freeze protect 2 gallons of water in a 3 gallon system then that is what I would apply by hand measurements with a gallon jug till full if I thought that The system might freeze!
Do reply I am in need of a laugh!
11/08/2007 10:47 PM
Check this link for some help on radiators
http://www.fwwebb.com/pdf/htgcat03/2003htgcat_p221-222.pdf
Unless you're the lead dog on the sled, the view is always the same....
KENN (1); PWSlack (1); Sniccus (1); Stirling Stan (2); Thadius (1)
