Previous in Forum: Cast-Iron Hot Water Radiators: Volume and Ratio   Next in Forum: Calculate Shot Weight + Runner and Sprue
14 comments
Stainless Steel Tube with a Square Cross-Section
11/05/2007 4:03 PM
Hi guys, I want to bridge a 7' span with tube to support the front edge of a built in computer table. I've found a company which does 20, 25, 30 mm square tube in 1.5mm wall thickness. The 25mm is also in 2mm wall thickness.
My gut feel is that 20mm is too small and that the 30 should be fine... they do 40 but I'd rather keep the size down (maximum knee room for wheelchair user).
Bear in mind it's fairly long and some one is going to sit on it eventually!
Is 30 @ 1.5 wall better than 25 @ 2mm wall?
What do you mech' eng' guys reckon?
(the top will probably be ply, about 20" front to back, supported along most of the back edge... a few cut outs for cabling.)
Cheers in advance
Good Answers: 66
Re: Square section Stainless steel tube
11/05/2007 4:58 PM
Del,
A quick FEA shows the 25x2.0 to deflect less. Forgive the mixed units, but a 10cm piece restrained at both end faces evenly loaded (distributed along entire top face) with 100lb, the 25x2.0mm profile deflected 0.00011" and the 30x1.5mm deflected 0.000396" (almost 4x). Hope this helps!
Edit: I assumed 304 Stainless, by the way. I re-ran the 30mm profile with 18" length (about as much as my weak-a$$ FEA will handle) and got slightly over 0.001" maximum deflection with same 100lb load.
Aequam memento rebus in arduis servare mentem.
11/05/2007 5:03 PM
Cheers...
11/06/2007 12:04 AM
30@1.5-- any time.
L/R is better.
mm
11/06/2007 12:43 AM
You should use rectangular section tube 20x30x1.5 for your computer table, with 30 is front section.
B/c of after building the table 20x30 is nicer than 30x30 or 25x25.
Nam
Nature is unlimited, human's knowledge is limited
11/06/2007 2:29 AM
I wanted rectangular, but can only easilly obtain the sizes stated in small qty reasonable cost.
As My granny used to say 'Ya cannae buy wha' they hav'nae got'
(I keep explaining to Mrs Cat ..this also applies to grocery shopping )
11/06/2007 6:17 AM
If profile is an issue, why not try a stiff hardwood instead? Oak planks are available in that length x 51/2in x 5/8in from J Gard and Sons, timber merchants, of East Hanningfield http://www.gards.co.uk/index.php (usual disclaimer).
11/06/2007 8:18 AM
You mean, with no 'beam' underneath? Could be goos and oak would look good. I'll look at the price..cheers .
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
11/06/2007 6:50 AM
Del:
FYI,
Next time you are wondering which type of cross section of tubing to use that has more stress resistance, just look up the Section Modulus (S) of the sizes you are considering. The Section Modulus is given in mm3 or in3. The higher the number usually indicates a higher strength for the applications you will be using them for. Section Modulus tables are usually available from the supplier or you can find them in the Machinery's handbook.
Dirt is for vegetables. Pavement is for racing.
11/06/2007 8:20 AM
I don't have a Machinery's Handbook .
I'll have a closer look at the suppliers website tho'
Cheers.
11/06/2007 9:16 AM
If you screw through into the wood top, this will also increase the rigidity! or if you put a slight upward bend in the beam! (only a very small bend!) Remember the trick with the karate chop? No! Hold a piece of wood about half inch square and a foot long out at arms reach, now just put a bit of upward bend in it! get your buddy to try and karate chop it! If you don't put the bend in it, he will slice through it like butter! so he holds it first, and you chop and break it, then he has a go, but you sneak in an upward bend and he nearly breaks his hand!!! Did this as a kid and had great fun with it!
11/06/2007 10:22 AM
Let me know what type of tubing you want, I'll get it too you.
Cheers
11/06/2007 1:47 PM
! Gasp .
..nice offer
...it's a long way to Harlow in the UK... Are you really serious!!!!????
I'll PM you with details... if you can make such a cool thing happen...you must be the steel tube wizard...
Cheers
Good Answers: 58
11/12/2007 9:47 PM
Try this site http://www.engineersedge.com/section_properties_menu.shtml
Re: Stainless Steel Tube with a Square Cross-Section
12/20/2010 2:51 AM
Not sure what the size is best for you, but you can check on this website for all sizes available for you. http://www.metal-supplies.com/8601/12753.html
Register to Reply 14 comments
CSM Engineer (1); Mr. Truman Brain (1); MUKULMAHANT (1); nam70 (1); nicksam (1); PWSlack (1); The Prof (1); unclefastguy (2); user-deleted-1105 (5)
