Previous in Forum: Graduation in Instrumentation   Next in Forum: DCS vs. PLC
DCS Configurations
11/06/2007 2:33 AM
What is DCS configuration ? i meant in plc configuration like Power supply, cpu, cp, counter module, analog input, analog output , digital input & output module then DCS?
Re: DCS
11/06/2007 5:59 AM
"counter module, analog input, analog output , digital input & output module" wouldn't be found in a DCS. Most of the signals would go to and from various satellite PLCs via a network these days.
Re: DCS Configurations
11/07/2007 8:19 AM
I'm not sure if I exactly understand your question, but we have both a Fisher Porter/Bailey and a Delta V DCS. Each of these utilize analog input, output and digital input & output modules. The Delta V does not have relay modules or isolated analog input modules. The FP utilizes a separate rack mounted power supply, while the Delta V has it's power supply and cpu mounted in a configuration much like you'd find with a PLC. Hope this is of some help.
"You can fool some of the people all of the time and you can even fool all the people some of the time, but you can never fool all the people all of the time." Abe Lincoln
11/08/2007 10:25 AM
Hi
im a Engineer with thirty year experience in DCS
and my opinion he is the following one
It is case the same with some variants by applications outposts
subsistems configurations(Controler , I/O´s interfases , processor data, operator station, ingenering station, Hi- density interfases, Comunications and Power supply)
Loops configirations (range, service, limits alarm, signal type)
Ambient or aplication configuratión (Dinamic Graphic en OS´s)
Reports Configurations(format, source of data, period)
The configuration is made generally on ES
I hope that my commentary helps
greetings you
11/16/2007 1:31 PM
See also:
dcs <http://globalspec.ip09.com/rd/9z1zjov9u02amc6005sii4nv5cv21u7nn6o5dcvpmcg> (Communications & Electronics)
Register to Reply 4 comments
bfmickl (1); gwood (1); Haajee (1); PWSlack (1)
You might be interested in: Distributed Control Systems (DCS)
