Previous in Forum: How to Build a Yagi Uda Antenna   Next in Forum: Why is Infrared (IR) Used in Remote Control?
Sensor for Controlling Household Lamps
11/06/2007 9:52 AM
I have my house with a number of lamps,I need to control these lamps in such a way that when there is light lamps should be off and ON in the presence of Dark.Can i get the complete circuit of the system. NOTE those lamps are Emergence lamps connected with commercial power.And they are rechargable.
Ruzuba Manuanga
Re: Sensor
11/06/2007 10:05 AM
www.x10.com has a bunch of home control stuff
Re: Sensor for Controlling Household Lamps
11/06/2007 12:11 PM
No need. Plug-in devices are available over-the-counter at any principal domestic hardware store.
11/06/2007 5:33 PM
Disclaimer: Contact a qualified electrician to do the job. Don't attempt this if you are not an electrician!
Apart from that, Do you mean, turn on when the power goes down? If yes, then connect it to your normal lighting circuit, not the switch wires, but the actual circuit that runs round to feed all the light circuits! If you want to get a bit more technical, you could have a dedicated circuit that has a test key before its own breaker! Emergency lights charge off the light circuit and automatically switch when there is a power out!
11/07/2007 12:38 AM
aviation red lights on any high towers, are controlled by such darkness sensing devices. for any flying objects, the presence of these towers are indicated by these red lights when it is dark. u may contact those tower erectors who r doing it for telecom towers. or else civil aviation deptt. concerned. hope u get an idea.
11/07/2007 10:28 AM
Common, cheap, night lights sold in hardware stores to grocery stores use that idea. Maybe they can be adapted to switch battery power instead of AC. Otherwise, purchasing a proper emergency light that is designed to a code is the quickest, easiest and ultimately the safest way to do it. Cheapest is a toss up. If you build yourself, you would still have to provide a battery, purchase components to build circuitry, construct some sort of pleasant looking (optional) enclosure. With LEDs and current battery designs, I'm sure there must be small, low profile, reliable and relatively cheap emergency lights available at big box hardware stores next to those smoke detectors (and CO detectors) that you should have installed years ago. And if you did, IT'S TIME TO CHANGE THEIR BATTERIES !
I installed four cheap night lights in strategic locations around the house in baseboard outlets. Now I don't stub my toes often any more. When the power goes out, which doesn't happen often, I'm on my own, but there's plenty of time between those occasions to recuperate.
Nothing exceeds like excess.
bhankiii (1); gajendrasingh01 (1); Jaguar (1); Mr. Truman Brain (1); PWSlack (1)
You might be interested in: Lamps, High Intensity Discharge Lamps
