Previous in Forum: Bobcat Fire   Next in Forum: Shape of Electrolytic Capacitors
15 comments
Electricty Generated by Slight Wind
09/24/2020 7:50 AM
A future application of this technology might enable embedded led's to illuminate a flag or road side billboards.
How about illuminating vehicles when in motion,for instance,motorcycles,bicycles,etc.,or joggers?
This could replace and be more effective than reflectors,which rely on reflected light.I see many applications for this.They could become ubiquitous.
I wonder when a company will offer an IPO ?
https://techxplore.com/news/2020-09-tiny-device-scavenge-energy-breeze.html?utm_source=nwletter&utm_medium=email&utm_campaign=daily-nwletter
Re: Electricty Generated by Slight Wind
09/24/2020 8:27 AM
Sounds great until it gets wet or clogged with a piece of dust.
I've been touting a way to harvest megawatts from thin air.
A method I testest and talked about here a decade ago.
Failure to observe the laws of thermodynamics was the warm response I received.
Last year I met with a buddy who owns and operates a successful electric component manufacturing facility in the burbs. He fully understands the concept and has been champing at the bit to get me building a newer better working prototype that he would fund.
I've been too busy playing catch up to consider a start date, and the pool of thought here just hasn't been invigorating.
09/24/2020 10:59 PM
How about a link to this ?
09/25/2020 10:01 AM
Vintage post
..dang phone.. must have updated to downgrade.
Later on
09/24/2020 10:40 AM
This is interesting, but I'm thinking, not a serious source of energy. I believe you could get more power out of a small wind turbine.
"In our work, the η of the B-TENG is about 3.23% at a wind velocity of 6 ms−1, which is much larger than the previously reported values ..."
(6 m/s ~ 12 mph)
"By increasing the wind velocity, the output performance of the wind harvester can be increased, reaching a maximum value at a wind velocity of 8 ms−1, including a voltage of 175 V, a current of 43 μA, and an output power of 2.5 mW."
(8 m/s ~ 16 mph)
The device lights 100 LEDs, not continuously, but intermittently by charging a capacitor.
https://ars.els-cdn.com/content/image/1-s2.0-S2666386420302228-mmc7.mp4
https://www.sciencedirect.com/science/article/pii/S2666386420302228?via%3Dihub
09/24/2020 2:33 PM
Great, another unreliable energy source...let's invest all our money in that useless tech...
09/24/2020 8:04 PM
I remember my parents insisting that my bicycle had to have a generator powered lamp. These have existed for more than half a century and used inefficient filament lamps!
09/24/2020 9:53 PM
And amazingly you can still buy them.
https://www.amazon.com/Wai-Danie-Generator-Waterproof-Alternating/dp/B07X2B1DVG/ref=asc_df_B07X2B1DVG
I do recall the additional drag was quite noticeable. I had one on my bike. LED's and a rechargeable Li-Ion battery are far more appealing.
09/25/2020 2:33 AM
True on the drag when applied to the front wheel. They came in 3-4W and 6-8W and lit the bike up well at night but did wear the tyre sidewall especially if dew got onto the tyre. There were even ones for the rich kids that were built into the front hub but I only dreamed of one of those.
All the ones I saw were AC, but a diode bridge and capacitor and you were a tech genius. Though the diodes were single none of those encapsulated bridges and electrolytic capacitors lacking capacity, "What they now have Farad capacitors, you're kidding me!"
I still have a couple in the shed somewhere.
Hare today, goon tomorrow!
09/25/2020 8:58 AM
I had one of those on my first bike. You could disengage it when it wasn't needed, but you could feel the drag when it was in use. One problem was that, when moving slowly like climbing a hill, the headlight was very dim.
Nowadays, you could rectify it and charge a rechargeable battery. I'm thinking that the only common rechargeables back then were heavy lead-acid and rectifiers were those funny looking things with the cooling fins.
09/25/2020 10:09 PM
Ah, yes. Selenium rectifiers. Do I get a gold star?
09/25/2020 10:52 AM
I still have an old Raleigh with the "rich kids" built-in generator hub. Still works. Original pinstriped paint job on the bike. Three speed rear hub. Front fork lock (quite a deterrent - thief had to carry the bike away instead of riding it).
09/25/2020 2:15 PM
Wind is generally methane if the person is a cabbage or legume consumer. It can be collected for use, but would generally require some sort of clothing modification to accommodate the plug, hose and bladder. Yup, I smell an IPO in the works.
09/26/2020 4:45 AM
Although the wind turns the windmill which turns a coil of wire through the magnetic field of the generator you cannot create energy. You can convert one type of energy into another. For instance, in a hydro electric plant, gravitational energy is converted directly into electrical energy. In the windmill, sunlight heats the air masses which results in wind blowing and this turns the windmill. The energy came from the sun. In fact, there is no other source of energy than sunlight. The energy comes to us in the form of photons. My rule: “Every action is caused by photonic energy”.
09/26/2020 8:07 AM
The exception to all energy comes from the sun is the little bit of nuclear power generated and the geothermal power harvested.
09/27/2020 7:15 AM
Generate electricity with a slight wind?
How about if it is combined with methane emissions from cows?
Or people for that matter.
Imagine traveling across country with a can or two of beans and a jar of pickled eggs!
Throw in a little broccoli and corned beef and you might get a round trip without stopping for a refill at your local truck stop.
A simple funnel under the seat with a vacuum hose to the intake of the fuel cell. Walla!
Register to Reply 15 comments
Brave Sir Robin (2); canadianslidewinder (1); elisecoen (1); HiTekRedNek (1); JE in Chicago (2); Jpfalt (1); redfred (2); Rixter (2); SolarEagle (2); Stef (1)
