Previous in Forum: Pump Size   Next in Forum: Heaters for a Gear Lubrication System
Cyclone Calculations
11/08/2007 2:44 AM
I would like to know the considerations for making cyclone selection calculations. I have got Manganese fines (-8 to +1mm) that I need to separate from the ore. It has been recommnded to use a Dense Media Cyclone with FeSi as the separating media.
What are the design calculations/considerations that I need to take care of? What is the Cyclone selection process like?
I have no mining experience, Please help.
Re: CYCLONE CALCULATIONS
11/08/2007 3:59 AM
Good Answers: 101
Re: Cyclone Calculations
11/09/2007 3:45 AM
What do you mean by -8mm diameter? Virtually all cyclones will remove at 50% of airborne particulates of diameter 10 microns and above. The larger the particulate diameter, the more effective the removal is.
Good Answers: 19
11/09/2007 9:48 AM
http://en.wikipedia.org/wiki/Cyclonic_separation
Link for simple explanation of cyclone separation. A copy of "Industrial Ventilation" by the ACGIH or "Fan Engineering" from Buffalo Forge will have additional design criteria.
Cyclones are usually custom fabrications. If you are lucky, maybe a local fabricator can offer some guidance on sizing based on a review of your process. I had similar help for a small paperboard separation cyclone.
11/10/2007 12:23 AM
Register to Reply 4 comments
Anonymous Poster (1); apcco (1); DVader1000 (1); Ried (1)
