Previous in Forum: Real-World Spherical Reservoirs   Next in Forum: Cyclone Calculations
31 comments
Pump Size
11/07/2007 11:11 PM
Hello friends
How to select Pump size plz reply me with formulas
Best Regards
SYED
Re: Pump Size
11/08/2007 12:10 AM
What r you trying to do? Application? Makes a defference!
Do reply I am in need of a laugh!
Good Answers: 97
Re: Pump Size
11/08/2007 12:31 AM
To select a pump you need the duty point (flow,working head) and any restrictions placed on the selection (speed, power, suction height, etc).
It is not clear what your intentions are, a bit of clarification may help.
In most cases with limited knowledge available it might be best to start at a manufacturer (or authorised distributor), The usually have detailed and selection pump curves and all other information needed. It is then as easy as reading it off a page.
Re: Pump Size
11/08/2007 1:10 AM
for choosing the pump size,
you must know what is the shut off pressure,NPSH required,material you are going to handle and their properties like temperature, corrosiveness nature, density and viscosity, and mainly flow rate.
Re: Pump Size
11/08/2007 1:37 AM
Let's start simple. Working head (that Hendrik mentioned in post #2), is also refered to as Feet of Head. This is simply the distance in feet, from the pump, to the highest point in the piping. Using that as a guideline, how many GPM/CFM/... will be needed to to supply required flow?
If you know how "high" the pump has to lift the "fluid", and you know how much flow you need, then the pump manufacturer can size the pump.
This is assuming that you are talking about a centrifugal pump; pumping something close to the viscosity (density/"thickness") of water. If you are talking about a positive displacement pump, pumping pulp stock, then there are other things to consider.
You will need to be more specific; if you want more help.
Re: Pump Size
11/08/2007 3:43 AM
What's the fluid -
  • Strawbetty jam?
  • Blood?
  • Sewage?
  • Liquid sodium?
  • China clay slurry?
  • Toothpaste?
Good Answers: 183
Re: Pump Size
11/08/2007 2:41 PM
what for? :
pressure
estimated flow
"fluid" to be pumped
where? (environmental conditions)
which type (if you already made a choice) ?
and evrything you can say about the application and then a correct suggestion can be made.
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
Re: Pump Size
11/09/2007 3:09 AM
If you are talking about an (oil) hydraulic system, you need to start with the end user (cylinder or motor) and work back to the pump.
The pump does not provide the pressure (the system does that), it only provides the flow (by virtue of displacement) therefore the static head becomes a (small and largely irrelevant) component of the system.
Anyway, tell us more (as all the other learned people have said) and perhaps we can be of real help to you.
Remember: an answer is only as good as the question posed!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
Re: Pump Size
11/09/2007 6:38 AM
Another thread with no useful info to make helping easier......!
Re: Pump Size
11/11/2007 4:35 AM
That's the wrong size pump Andy could you please try another one. Or is that being facetious.
Re: Pump Size
11/11/2007 4:44 AM
Is this big enough??
Re: Pump Size
11/11/2007 5:16 AM
No, no NO!
He was after a SAE 2 bolt 'B' flange pump with Ø 1.25" parallel shaft.
I think yours is the size larger and it's got a taper shaft!
He may get back to us and confirm this. Then again.........!
Re: Pump Size
11/11/2007 7:02 AM
Oh drat!!!
My most sincere apologies, I didn't really mean to over design the pump.
What the hell, it won't be overloaded.
Re: Pump Size
11/11/2007 7:45 AM
And I think your pump is a (water) motor with a generator stuffed on the end!
Mind you, with the info' we have to work with, it might still be ok! He could run it backwards, then it would be a pump!
Re: Pump Size
11/12/2007 5:17 AM
Ah ha! Eureka....... I have found it!!!
Hydro electric power. Don't tell anyone our little secret.........we will be rich.
Re: Pump Size
11/12/2007 6:05 AM
Thank God for that! I'm 'brasic lint' at the moment!
Re: Pump Size
11/14/2007 8:58 AM
We could try our little plan down in Tassie and when we have finished with the water send up here to the land of the crow eaters.
Re: Pump Size
11/14/2007 3:39 PM
Hi Mobi. I think it's already been done down here in Tassie. The lights are still on anyway. Good idea to send the water up your way though. We could charge more than for a Ltr of petrol.
You could be the agent for the North island and me for the South. Deal?
Re: Pump Size
11/15/2007 9:08 AM
OK Number One, it's a done deal. (watching too much TV I think)
By the way what's this North Island crap ???? You must be a true blue Taswegian.
Re: Pump Size
11/15/2007 3:44 PM
Nope, actually, I'm a pome! I was brought up not too far from where Del the Cat lives in the UK. I've only been in Tassie for five years and am now moving to QLD. It's too cold and wet inTassie for Mrs Beej!!!!!
Oh! That means that we would both be agents on the North Island! Send me an email when you get time. I have no contacts anywhere up your way!
Re: Pump Size
11/09/2007 7:00 AM
I wish I had the power to delete threads like this one. Mental laziness is defined as: "How to select pump size reply with formulas" or more simply "The lack of will or, your inability to put your thoughts together in an orderly and intelligent manner."
Wangito.
Never trade luck for skill.
Re: Pump Size
11/09/2007 11:00 PM
i asked a ? how to calculate pump size normally for calculating the pump size flow rate is required but assume the flow and what ever the rquirement and u have to rep if u know............but dont excuse by telling mental laziness ...........i think this is suitable for u peoples
Re: Pump Size
11/09/2007 11:34 PM
a) Please re-phrase your question. If you need help, find someone who can modify your grammar for you. It's coming over a bit blunt!
b) Please take note of all the learned contributers to this thread and SUPPLY YOUR SPECIFICATIONS OR REQUIREMENTS. Then (as if by magic) you will get relevant answers!
Re: Pump Size
11/12/2007 8:56 AM
Please read my earlier comments again.
Now, calm down.
See, these people who are responding to you (except myself) are the most learned people in the industry and eager to help you. Tell them exactly what you are looking for and you will see that they will help you. Many of them are the people who work for the pump companies.
No need to aggravate yourself and anyone else. Just ask nicely with all the requested infromation that they asked you to give and you will have the answer in your hand quickly.
Regards;
Nadeem Butt
11122007
May God keep y'all in his blessings Nadeem Butt
Re: Pump Size
11/09/2007 8:52 AM
In asking questions, you should be more specific and polite to request the info and not order around. The words like please do not hurt any one and people open up to help. There is a world of experience at your disposal. Just tell us exactly what you are looking for and every one of us would help you the best we can.
The solution becomes very easy if you analyse the problem and unfortunately, your question does not. Also, there are text books which will tell you all about design of the pumps.
So, I would request you to please go back to your question and ask us again and this time be very specific as designing the pump is easy and pump manufacturers are big help to design with your process data.
Regards;
Nadeem Butt
11092007
Re: Pump Size
11/09/2007 9:46 AM
Good Answers: 12
Re: Pump Size
11/09/2007 12:33 PM
I rply you formula
P=F/A Q=V/T HP=PQ/1714 V = VA = C(ß)= SG = Cv = Q = HPIN = or EffQV= x 100
EffQV = EffVOL x EffMECH EffVOL = x 100 EffMEC = x 100 B10 x x
The formula you need is listed above.
Tell the community what you are trying to do and we can tell you which formula and how to use it.
Recommendation: Sign up - then state your problem giving specifices as to application. Is it for home, work, school science project, etc? How much fluid is to be moved, how accurately, visconsity of fluid, etc?
Re: Pump Size
11/13/2007 10:43 AM
sir iam an mechanical engg from india.i want to know how i can used these farmulas.
Re: Pump Size
11/13/2007 11:28 AM
Vimal:
I am a chemical engineer from Jabalpur, MP, India.
Please use correct English when you write. Pay attention to what you write. Remember you are exposing yourself to the world and what people think that a mechanical engineer from India cannot write correct English?
Read your text books and go to the library and you will find many answers to your many questions. These people are very learned ones and will help you a lot. Just be specific in your questions. Their answers will be very precise and to the point only if they know what you are looking for and how you want to use the information.
I apologize for writing this and I hope I have not offended you in any way..
Nadeem Butt
11132007
Re: Pump Size
11/09/2007 1:17 PM
Retain the services of a professional mechanical engineer!
from a PE
re:Pump Size
11/14/2007 9:42 AM
OK Guest,
Here we go.
Most pump companies have something similar to this, I am just familiar with this one.
Go to paco-pumps.com...on the very front page , on the left side, there is something called Pace Express.
Enter the desired FLOW (in GPM or what ever you want to set your units to) and HEAD (also known as pressure). Tap the Go button. This will give you choices such as motor speed, Hertz, etc. Tap the next key. This takes you to a page which gives you a list of available types of pump. Select as many different styles as you like and tap the next button. This will list all available pumps from that manufacturer initially sorted by efficiency. Select one and you will get all the pertinant information you want to know. Sorry, no formulas. Just leaving it to the experts to figure all that stuff out.
Hope this helped. Good luck. And may this thread end.......now!!!
Re: Pump Size
12/04/2007 5:28 AM
To select a pump size, you have to calculate the power to be performed by that pump.
Hydraulic Horsepower of Pump = (GPM) (H) (S.G.) / 3960 = (GPM) (P) / 1714
where,
GPM = Liquid flow rate, gpm
H = Total head to the pumped liquid, ft
S.G. = Specific gravity of liquid
P = Total pressure drop, psi
Reply to Forum Thread 31 comments
Abdel Halim Galala (1); Andy Germany (1); Anonymous Poster (2); Beej50 (7); Capt Psycho (2); Hendrik (1); Kilowatt0 (1); MOBI (6); Nadeem0430 (3); nick name (1); PWSlack (1); Rathinavelu (1); Snave (1); Thadius (1); vimal (1); wangito (1)
