Previous in Forum: Tensión mecánica de conductores   Next in Forum: 33KV SWGR Earthing System
Low Voltage and High Frequency Signal
11/08/2007 2:50 PM
is any other the ways to convert A/D signal about 10 mV, 2* 10^8 hz with out using Pre-amp?
Re: low voltage and high frequency signal
11/08/2007 5:17 PM
At what resolution do you want to get? Are you looking to create a square wave then no a comparitor would do it, if you are looking to build an 8-bit representation then yes!
11/08/2007 7:16 PM
Im interesting.
200Mhz sample, how mcuh bits? and s/n?
what do you want to do?
11/09/2007 5:51 AM
Are you looking for an integrated circuit or a PC plug in board (or what?).
National semiconductors do a 170 MS/s 3.3 V 12 bit ADC; that would give you 3 bits of resolution but not quite at 200 MHz.
There are lots of PC plug in boards that do 12 bit, +/- 200 mV at 200 MS/s. That would give you 6 bits of resolution.
What are you trying to do?
What about a cheap DSO?
11/12/2007 12:32 AM
if 10mv at 10bits converter, noixe will be less than 10uv.
12bit less than 5uv.
it may be a hard work
Re: Low Voltage and High Frequency Signal
11/15/2007 11:20 PM
If you are only dealing with 200 MHz, dont forget about undersampling.
Anonymous Poster (2); cnpower (2); Randall (1)
