Is it correct that when sizing a pump to be used in an orifice plate metering system, that the flow of the pump is not all that important but rather the pressure it can supply. I have done many experiments that seem to indicate this and also when calculating the flow through the orifice, upstream pressure seems to be the biggest factor as it determines the pressure drop. I have a fixed pipe, fixed orifice dimensions, fixed fluid density and flow coefficient, so my main variable is the pressure drop. I have used pumps with a wide range of flow specifications, but that does not seem to matter since the flow is practically stopped with exception to flow through the plate. The only noticeable difference is the pressure generated by these pumps. It seems to make perfect sense to me as all my calculations are almost spot on with the actual volumetrics taken. I'm just wondering if I need to look more to pressure versus flow in pump selection. Thanks for any assistance.
