Previous in Forum: Halogen Lamp Gas - Mathematical Coefficients   Next in Forum: What Happens to Water in a Vacuum?
13 comments
Polypropylene Adhesive
11/09/2007 9:34 AM
I need to "glue" some 30% glass filled polypropylene parts together, is there a good off the shelf adhesive that is available? Thank you.
Popular Science - Weaponology - Aerospace nut Hobbies - Musician - music enriches the soul United States - Member - Happy to be from the USA Engineering Fields - Acoustical Engineering - Pro Audio Speaker Designer Engineering Fields - Manufacturing Engineering - Aerospace ME Engineering Fields - Aerospace Engineering - Airplane nut from aeromodels to 747's
Re: Polypropylene adhesive
11/09/2007 10:22 AM
the old standard used to be 3M EC2216. There may be some better ones out there now a days. During the 70's and 80's it was the only adhesive that was approved by the FAA. I ususally use the gray but that depends on your application.
PDF datasheet
Good luck,
Scooter
The early bird gets the worm, but what about the early worm? A.E. Neuman
Good Answers: 18
11/10/2007 7:48 PM
Is the "old standard" just MEK?
11/12/2007 3:48 AM
Er, MEK won't work. Polypropylene doesn't dissolve in it.
11/12/2007 11:50 AM
the "old standard" used to be "3M EC2216"
this is a 2 part epoxy.
Re: Polypropylene Adhesive
11/09/2007 12:09 PM
Excuse my curiosity (hey ...I'm a cat!) but glassfilled polyprop' seems slightly unusual to me ...what's the appliction? Is it chemical resistance you need?
11/09/2007 12:33 PM
The reason we use the glass filled is for strength. The polypro itself has the chemical compatibility we desire.
11/09/2007 12:36 PM
Ok...yup that's what I wondered...we have a few bits made in polyprop' for that reason...just curious.
Cheers
11/10/2007 3:44 AM
I was under the impression that glue bottles are made of polypropylene because nothing will stick to it.
11/12/2007 3:49 AM
....not even cyanoacrylate!
11/12/2007 3:50 AM
Is it possible to fusion-weld the parts together using heat?
How about ultrasonic welding?
11/12/2007 11:57 AM
ultra sonic welding works, I don't know about the fusion weld.
It seems to me that there was a surface prep that was used to bond with epoxy, I think it was an acid etch of some kind. It discolored the plastic before bonding. There was also a process that used a solvent to soften up the surface before bonding (it was called "activating" the surface). Its been too long since I did this and the memory isn't what it used to be...
I would contact the adhesive manufacturers and ask them.
01/01/2008 2:08 AM
Any you guys remember the Hobie Hawk R/C glider from back in the '70's?
The fuselage used a front section made of either polypropylene or polyethyelene
Anyway the manual advised "flame treating" this part of the fuselage so that it would take paint. I used too much "flame treating" and warped mine. It still flew well, though.
In the meanwhile I need to glue polypropylene to expanded polystyrene foam.
Any suggestions?
01/07/2008 1:44 PM
Well the heat trick works pretty well but you must keep control of your heat source .
The 3M EC-2216 works pretty good under these conditions and will work great with the polystryene foam.
How big of an area do you need to glue? I use 2216 all the time to glue the sides on profile fuselages and I've used it to skin wings.
Scott
Register to Reply 13 comments
AcesFull (1); agua_doc (1); dayhead (2); PWSlack (3); snewkirk (4); user-deleted-1105 (2)
You might be interested in: Adhesive Dispensing Equipment, Adhesive Tapes, Plywood
