Previous in Forum: Use Nitrogen Cylinders Without Pressure Regulator   Next in Forum: Sample Cooler Design
SA 516 70
10/20/2020 8:53 PM
Hello,
Is there is any book guidance for SA516 70 to see the properties as a function of temperature .Any guidance would be helpful. Or any aluminum alloys properties is similar to SA516 70?Thank You
Re: SA 516 70
10/21/2020 3:06 AM
  • Talk to a Mentor at the facility. After all, the design documentation will be going through a second-person-sanity-check, won't it?
  • Engaging in discussion with the Engineer/Surveyor from the organisation supplying burst/collapse indemnity insurance cover on the equipment is something that cannot happen too early. After all, this organisation will also carry out a sanity-check on the design documentation, won't it?
Do let the forum know the outcome of these discussions, as it will be helpful to other subscribers.
