Previous in Forum: coloring of stainless still   Next in Forum: Coating of MS Blade
8 comments
calculation
11/11/2007 8:41 AM
How to calculate chang in temp if air at 30 Kg/cm2 pressure & 320 oC reduced to 8 Kg/cm2 pressure
Re: calculation
11/11/2007 8:55 AM
Good Answers: 19
Re: calculation
11/19/2007 8:08 AM
You confused me. Now I don't know what i know now how can I know what I don't know.
Re: calculation
11/19/2007 3:32 PM
Sorry, but don't shoot the messenger.
Have a look at the poetry of D H Rumsfeld.
Re: calculation
11/12/2007 1:32 AM
PV=nRT, nR is constant, so PV/T = PV/T ffej
Good Answers: 32
Re: calculation
11/12/2007 9:36 AM
I believe you are referring to the Joule-Thomson effect:
"In physics, the Joule-Thomson effect, or Joule-Kelvin effect, is a process in which the temperature of an ideal gas does not change, but the temperature of a real gas is either decreased or increased by letting the gas expand freely at constant enthalpy(which means that no heat is transferred to or from the gas, and no external work is extracted)."
http://en.wikipedia.org/wiki/Joule-Thomson_effect
http://prola.aps.org/abstract/PR/v13/i6/p438_1
Tad
United Kingdom - Member - New Member Engineering Fields - Energy Engineering - New Member Engineering Fields - Piping Design Engineering - New Member Fans of Old Computers - Commodore 64 - New Member Technical Fields - Technical Writing - New Member
Re: calculation
11/12/2007 11:27 AM
Assuming an ideal gas, and constant volume, calculating the new temp will be straightforward.
T2 = (P2xT1)/P1
Remember to convert your number to SI units before performing the calculation. i.e. Temperature in Kelvin = Temp Celcius + 273.15 and Pressure in Pa = Press kgf/cm^2 x 98066.5
DesEng
Those who believe in telekinetics, raise my hand - Kurt Vonnegut
Re: calculation
11/12/2007 12:52 PM
If volume is not constant, when the gas expands it is doing work, hence it is losing energy. Isentropic expansion (reversible adiabatic) is typically used to calculate the result when volume is not constant, for example the output of an air compressor. I believe the following equation will approximately calculate the change in temperature where T is absolute temperature and p is absolute pressure for diatomic gases, like air. (From my old Marks Standard Handook for Mechanical Engineers).
T2/T1 = (p2/p1).286
Not too sure about my SI conversions, but I get T2 to be 261 deg C.
Re: calculation
11/23/2007 7:07 AM
u can calculate the temp by considaring the ideal flow
and the relation of politropic procss
Anonymous Poster (2); design-engineer (1); ducon (1); Howetwo (1); JohnDG (2); Tad (1)
