Previous in Forum: Option for Process Control is DCS or PLC ?   Next in Forum: Instrument cables
8 comments
help me up with my controller...please
11/12/2007 1:54 AM
to all my dear engineers: )
can you guys help me on my project...??i'm doing my neuro-fuzzy temperature controller fo heat exchager
well actually i'm setting up downscaled heat exchager where all the sensor and actuator will be control by the neuro-fuzzy controller via PC
guys,the problem was...how do i interface the controller with the sensor and actuator???do i need a data logger or DAQ system to controll my process, and i cannot affort expensive equipment..i'm so confused on this and is there any easiest way that i can control my heat exchanger without using PC
Re: help me up with my controller...please
11/12/2007 3:22 AM
at first, you have to speak, what type is you controller?
digital or analog? whts it interface to sensor or actuator? d or a?
whats interface to computer? p,or s terminal? etc.
so taht we can give you an idea.
most intellegent controller neednt computer, it can control tempereature by itself.
11/13/2007 3:59 AM
my controller is AI neuro-fuzzy controller.....i'll program the controller using the MATLAB7 and in a personal computer(PC) the i let the PC as the base of my controller...that mean i will control all my sensor and actuator via PC....and what do u mean the interface p or s terminal???and which do u prefer???
tq for ur assistance sir: )
11/14/2007 1:37 AM
two ways for you to make,
1,
neednt use any ocntroller, but your pc enough! you can use i/o to drive your actuators.after program in you r pc. in way of your neuro fuzzy program.
you can use a microchip, and burn your program into it.
you seems to like use the first way.?
11/12/2007 11:50 PM
Yes there is an easy way. Please e mail me what you are doing and I will send you a diagrahm from a recent job I just completed.
miketheboilerguy@aol.com
Good Answers: 114
11/13/2007 1:56 AM
11/13/2007 4:07 AM
how do i set this type controller to be a neuro-fuzzy controller.....my purpose is that i want to use a neuro-fuzzy controller by setting this controller using a personal computer(PC), and the PC will be my controller and via this PC also i will use to controll all sensors and actuators...how do connect the sensors and actuator to my PC, on the other word how do this sensor send and receive the signal via PC...do i need a devise in between the PC and the sensors
tq for u'r assistance sir:)
Good Answers: 114
11/13/2007 11:42 AM
What is it you are actually trying to do?
Why is neuro-fuzzy required?
Can your heat exchanger/servo be independant from the rest of your system?
11/13/2007 5:06 PM
Are you sure you don`t want to use PC , did you try microcontrollers , what kind of actuators and sensors are you considering
Register to Reply 8 comments
Anonymous Poster (1); cnpower (2); fendi_3606 (2); Garthh (2); vikas (1)
