Previous in Forum: HOW TO REDUCE THE NOICE LEVEL OF A GENERATOR?   Next in Forum: Reactive Power
Stephen Hawking's Imaginary time
11/12/2007 4:28 AM
Stephen Hawking's quantum cosmology uses "imaginary time" as more fundamental than "real time". The principle of causality only makes sense in real time where there are light cones at each spacetime point event. It is violated in imaginary time. The missing mass enigma may be a clue that real time is only the top of an iceberg. Most of the universe may still exist in imaginary time. Mathematically spacetime is described by a metric tensor which has a topological property called the "signature". The light cone only exists in real time where the signature is -+++. There is no light cone in imaginary time where the signature is ++++. The phase transition from imaginary to real time which starts the Big Bang is a topological transition. Is it controllable from the far future of real time in a self-consistent loop? Imaginary time sounds like something from science fiction, but it is a well-defined mathematical concept: time measured in what are called imaginary numbers. One can think of ordinary real numbers such as 1, 2, -3.5, and so on as corresponding to positions on a line stretching from left to right: zero in the middle, positive real numbers on the right, and negative real numbers on the left.
Imaginary numbers can then be represented as corresponding to positions on a vertical line: zero is again in the middle, positive imaginary numbers plotted upward, and negative imaginary numbers plotted downward. Thus imaginary numbers can be thought of as a new kind of number at right angles to ordinary real numbers. Because they are a mathematical construct, they don't need a physical realization; one can't have an imaginary number of oranges or an imaginary credit card bill.
One might think this means that imaginary numbers are just a mathematical game having nothing to do with the real world. From the viewpoint of positivist philosophy, however, one cannot determine what is real. All one can do is find which mathematical models describe the universe we live in. It turns out that a mathematical model involving imaginary time predicts not only effects we have already observed but also effects we have not been able to measure yet nevertheless believe in for other reasons. So what is real and what is imaginary? Is the distinction just in our minds?
Einstein's classical (i.e., nonquantum) general theory of relativity combined real time and the three dimensions of space into a four-dimensional spacetime. But the real time direction was distinguished from the three spatial directions; the world line or history of an observer always increased in the real time direction (that is, time always moved from past to future), but it could increase or decrease in any of the three spatial directions. In other words, one could reverse direction in space, but not in time.
On the other hand, because imaginary time is at right angles to real time, it behaves like a fourth spatial direction. It can therefore have a much richer range of possibilities than the railroad track of ordinary real time, which can only have a beginning or an end or go around in circles. It is in this imaginary sense that time has a shape.
To see some of the possibilities, consider an imaginary time spacetime that is a sphere, like the surface of the Earth. Suppose that imaginary time was degrees of latitude. Then the history of the universe in imaginary time would begin at the South Pole. It would make no sense to ask, "What happened before the beginning?" Such times are simply not defined, any more than there are points south of the South Pole. The South Pole is a perfectly regular point of the Earth's surface, and the same laws hold there as at other points. This suggests that the beginning of the universe in imaginary time can be a regular point of spacetime, and that the same laws can hold at the beginning as in the rest of the universe. (The quantum origin and evolution of the universe will be discussed in the next chapter.)
Another possible behavior is illustrated by taking imaginary time to be degrees of longitude on the Earth. All the lines of longitude meet at the North and South Poles. Thus time stands still there, in the sense that an increase of imaginary time, or of degrees of longitude, leaves one in the same spot. This is very similar to the way that ordinary time appears to stand still on the horizon of a black hole. We have come to recognize that this standing still of real and imaginary time (either both stand still or neither does) means that the spacetime has a temperature, as I discovered for black holes.
Re: Stephen Hawking's Imaginary time
11/12/2007 4:30 AM
There are two very important aspects of imaginary time that are not mentioned. 1) imaginary (or Euclidean) time corresponds to equilibrium thermodynamics: if a system is held at a temperature T, one can set time= i /( k_B T ) where i is the imaginary number 2) Making this transformation converts the Schroedinger equation , which has wave solutions into a diffusion-like equation. This is much easier to calculate with and is the basis for most numerical methods to treat quantum systems with more than 3 particles. see articles on lattice guage theory or quantum monte carlo. These two aspects are of great practical importance in our understanding of quantum systems.
An additional 'clue' that an imaginary time axis is relevant to real physics lies in relativistic formula for "distance" =√∆d2 - ∆t2 . If the universe is actually built on imaginary time τ ≈ i•t, then that peculiar '-' sign is there because we are [for whatever reason] using t, where squaring iτ=-t2.
11/12/2007 4:31 AM
In Nutshell, you still rely on imaginary time. I realise it is a mathematical tool but wondered if we had a clearer physical picture of what imaginary time actually is?
Any picture of time is a mathematical tool according to the positivist philosophy of science I adopt. In this, a physical theory is a mathematical model. We cannot ask if a model corresponds to reality, because we have no independent test of what reality is. All we can ask is whether the predictions of the model are confirmed by observation. Models of quantum theory use imaginary numbers, and imaginary time in a fundamental way. These models are confirmed by many observations. So imaginary time is as real as anything else in physics. I just find it difficult to imagine.
11/12/2007 4:38 AM
Imaginary time - The imaginary time T is defined by: t it'. This simple substitution is rather controversial in the community of theoretical physicists. Some argue that it is merely a mathematical trick, or a convenient tool devoid of any physical significance. Others suggest that imaginary time is the true physical quantity. Whatever its merit, imaginary time does provide an alternate computational technique and conceptional viewpoint as shown in the following examples (Note that imaginary and real are just mathematical terminologies in this context. It has nothing to do with the usual connotation of mental perspective.).Quantization of particles and fields is most elegantly prescribed by the method of path integral. The mathematical formula in term of the real time t for the probability amplitude to go from q(t1) to q(t2) is proportional to:
where the sum is over all paths and L is the Lagrangian (a function of the position and velocity). The oscillating factors in this formula are very difficult to manipulate. However by substituting the real time with the imaginary time, Eq.(22a) is changed into:
which become the more manageable exponentially decreasing functions. At the end of the computation, the imaginary time can be switched back to the real time.
Meanwhile, if the imaginary time is substituted into Eq.(10), it changes into a form familiar to Euclidean geometry:
ds2 = dx2 + dy2 + dz2 + c2 dt'2 ---------- (23)
While the real time in Eq.(10) restricts the time direction within the light cone, for the imaginary time there is no difference between the time direction and directions in space. Thus according to Hawking, it is possible for such space-time to be finite in extent and have no singularities that formed a boundary or edge. Space-time would be like the surface of the earth, only with two more dimensions. Such Euclidean sphere has zero points at the North andSouth Poles, but these points would not be any more singular than these Poles on earth. The corresponding universe in real time would have a minimum size, which corresponds to the maximum radius of the history in imaginary time. At later real times, the universe would expand at an increasing inflationary rate to a very large size By combining the two examples as illustrated above, a path integral similar to Eq.(22b) can be used to calculate the probability amplitude for the no boundary universes. The sum over histories is actually performed backward in time from the current state of the universe such as three-dimensional and flat, then construct the set of all possible histories that would end up like ours (with variables such as inflation, big crunch, ...), and finally sum them up by assigning a weighting factor to each to produce the probability amplitude for the history of a certain universe
11/12/2007 4:53 AM
The mathematics behind this approach to quantum theory contains an oddity: the answers only come out right when the calculation is done in imaginary time. That doesn't mean make-believe time, but rather a time dimension that is expressed using complex numbers. This is not an entirely esoteric idea: electrical engineers routinely use complex numbers, which are split into "real" and "imaginary" parts, to design electrical circuits. In the hands of cosmological engineers, imaginary numbers turn out to have profound consequences.
Hawking and Hartle's original work on the quantum properties of the cosmos suggested that imaginary time, which seemed like a mathematical curiosity in the sum-over-histories approach, held the answer to understanding the origin of the universe.
Add up the histories of the universe in imaginary time, and time is transformed into space. The result is that, when the universe was small enough to be governed by quantum mechanics, it had four spatial dimensions and no dimension of time: where time would usually come to an end at a singularity, a new dimension of space appears, and, poof! The singularity vanishes.
In terms of the universe's history, that means there is no point A. Like the surface of a sphere, the universe is finite but has no definable starting point, or "boundary". Hence the idea's name: the no-boundary proposal.
11/15/2007 6:16 AM
Good day to you S.H. : As a person sticking his toe in the icy waters of mars before plunging in, if I follow your description of the universe correctly, does it mean that the big bang event in time is simply a point on the surface of a sphere ( this sphere representing all of the known and unknown, to date, universe ) and so , there is no beginning or end, but infact a definite probability that it- the big bang- can reoccur and has occurred more than once ?
