I am designing a machine that uses three, spring loaded toggle devices that are arranged horizontally in line. Each device acts independently of the other two, and only one device is actuated at any given time. The forces acting on any one device are vertical; a downward manual force causes toggling against a stop while an upward force will reset the device past toggle against another stop. The total vertical distance traveled is about 1 inch. The vertical reset force needed to go past toggle will be at least 100 pounds.
My challenge is with the means to reset past toggle. An initial manual action by a human (pushing on a foot pedal) needs to activate some type of electrical device (linear actuator, gear motor, clutch/brake, solenoid, etc.) that will complete the resetting action, eliminating a continuous manual input. However, if the electric reset function is disabled for any reason, the toggle reset must be completed by continuing the manual force input. Keep in mind that whenever any one of the three toggle devices is reset the other two will not be reset.
I would like to be able to use one electrical device to provide the power for resetting the three toggle devices. This solution could become very mechanically complex. An alternative would be to use an individual electrical device for each toggle reset. This solution could become too expensive. There's always a trade off.
I would welcome any comments and suggestions on how to approach a design solution for this machine. Thank you.
tightwoods
