Previous in Forum: Calculation of pumps   Next in Forum: Selective Reset of Toggle Devices
Heat Treatment of "SK5"
11/13/2007 11:13 AM
Does anybody know anything about the Heat Treatment of SK5? My friend from China is helping me try to figure out what kind of material I should use on my Project and She talked about a SK5 steel that had properties like spring steel. I have tried to find information about the material and how to heat treat it and came up with nothing. Is SK5 slang for something else? Any help would be appreciated and it might save me from pulling my hair out.
Pathfinder Tags: materials steels
Re: Heat Treatment of "SK5"
11/14/2007 1:32 AM
Dear Sir,
As I know SK5 is a Japan tool steel. Its equivalant is DIN 1.1625.
Soft Annealing Temp 680-710 oC Hardness 190 HB 30 640 N/mm2
Hardening Temp (in water) 780-810 oC Tempering Temp 200-300 oC for hot working
and 180-300oC as a carbon tool steel Hardness after hardening 64 HRC Depth of Hardness 2.5 to 4 mm
On heat treatment all conditions required for tool steels should be followed.
I hope this information enough for your requirements.
Regards
Taner Mersin
11/14/2007 8:41 AM
Thank you for your information. It is very helpful.
11/15/2007 12:42 PM
Carbon Tool Steel
JIS Notation SK5
Chem. Comp% C=0.8>0.9, Rest max.>: Si--0.35 ,Mn 0.5, P,S 0.03
Used for making: Steel Stamp, Snap,Press Die, Spring, Band Saw, Circular Saw, Pen Nib etc
Heat Treatment :
1. To Anneal: Slow Cool from 730>760 degC Final HB 207max.
2. To Harden: Quench in Water from 760>820 degC
3. To Temper: Air Cool from 150>200 degC
After Hardening&Tempering you get Hardness Minimum HRC59
8888888888888888888888888The above is from JIS Handbook
Register to Reply 3 comments
Anonymous Poster (1); dan915518 (1); MUKULMAHANT (1)
