Previous in Forum: High Energy Metal Forming   Next in Forum: Identification Method for Defects in Raw Material of EN8D Bright Bar
Anchor Flange Axial Load Calculation
01/06/2021 2:49 AM
How can I design an anchor flange ?
pipeline axial load is given
Design condition,
Pipe line Material API 5L Gr. X65
Flange Material ASTM A694 F65
Des. Pressure 360barg
Des. Temp 85deg. C
thanks in advance
Re: Anchor Flange Axial Load Calculation
01/06/2021 7:41 AM
One could start by obtaining the pipe wall thickness, the pipe diameter, the stresses that are required to be accommodated, the details of what is intended to be <...Anchor...>ed to, the details of the lagging and lagging covering <...Temp 85deg. C...>, and then handing the problem over to a local Mechanical Design Engineer.
01/06/2021 9:07 AM
...after all, the forum knows nothing of <...I...>'s capabilities.
01/06/2021 9:55 AM
01/07/2021 12:36 PM
Great site, but the provided example may not be thoroughly up to ALL currently applicable Code Section(s).
MR. Guest (1); PWSlack (2); SolarEagle (1)
