Previous in Forum: Research a Taper FOS   Next in Forum: Electroplating: Black Spots in Chrome Plating?
Rubber/polymer lined cylinders for rice dehusking machines
11/14/2007 11:04 PM
Anyone out there familiar with rice mill equipment? I have one question regarding the rubber/polymer lined cylinders used on rice dehusking machines. What is the liner material? Is it a compunded rubber material or is is polyurethane. I have a sample worn out cylinder right in front of me. Is there a layman´s test to tell whether the liner is a rubber blend or PU? Any hints will be appreciated?
Re: Rubber/polymer lined cylinders for rice dehusking machines
11/15/2007 12:21 PM
You can try burning a VERY small sample of it. Polyurethane has a very distintive smell when it burns. If you are not familiar with it, find a sample of known urethane and test it first and compare odor. Of course you want to just get the odor and do not want a lungfull there are toxic compounds present.
11/15/2007 1:14 PM
That´s a start. Thanks for the word of caution.
11/16/2007 1:12 AM
Generally, PU is used for the application because of better abrassion resistance. If the existing material colour is other than black, there is a better chance of it being PU.
Register to Reply 3 comments
Anonymous Poster (1); coffeebean (1); Humble Ess (1)
You might be interested in: Hydraulic Cylinders, Air Cylinders, Rodless Cylinders
