Previous in Forum: Rubber/polymer lined cylinders for rice dehusking machines   Next in Forum: Do we need to make changes to our boiler feed?
9 comments
Electroplating: Black Spots in Chrome Plating?
11/15/2007 12:27 AM
Hi, these days we are getting problems with our electroplating plant when we go for chrom plating we get black spots in corners.suggest where should be problem and remidy
Popular Science - Weaponology - Aerospace nut Hobbies - Musician - music enriches the soul United States - Member - Happy to be from the USA Engineering Fields - Acoustical Engineering - Pro Audio Speaker Designer Engineering Fields - Manufacturing Engineering - Aerospace ME Engineering Fields - Aerospace Engineering - Airplane nut from aeromodels to 747's
Re: Electroplating: Black Spots in Chrome Plating?
11/15/2007 9:47 AM
you probably have either contamination in the tank or your plating with too much current. Its most likely that you have some contamination.
If your getting balling and a thicker plate at the corners as well then your current is too high. It is also possible that your plating solution is too strong which would allow more current (because of less resistance to the solution).
Even less likely is that your final clean and rinse solutions are contaminated which is leaving smut on the parts being plated and causing the plate to be poor. This you would expect to cause problems all over the parts not just in the corners.
Are you using a buffered solution?
Scooter
The early bird gets the worm, but what about the early worm? A.E. Neuman
11/16/2007 12:23 AM
Thanks Snewkirk, Thank you vary much for suggetions, we will go through for analysis of plating solution to check the contamination.
11/15/2007 11:25 PM
Hi,
We have an EPL (Electro-Plating-Line) - Black spot at the conductor entry is a problem, spots and streaks every where is a problem.
Chemistry of the dipping tanks and stirring are some answers.
Temp and current controls ................... more issues.
Enjoy a long, hard project to get a handle on Black Spot.
Regards,
Macker
Hummm..........Ponderous.........Creative thought and dreams are the seeds of actions !!!!
11/16/2007 12:10 AM
Please don't tell Chip Foose or Boyd Coddington, they'll probably order their plating like this as a design change!!
11/16/2007 10:37 AM
Sounds like you all work for Harley Davidson. They cannot get their chrome to work well either.
11/16/2007 10:52 AM
I only have a little experience in depositing, and that from washcoating, not plating. If I may ask a question just for knowledges sake? I'd expect contamination left from a wash solution, or thicker plating in the corners to be a surface tension/wetting issue.
Why would electroplated material build up in corners of a flat sheet?
Thanks,
Rick
11/16/2007 11:17 AM
I don't remember the physics but you always get more current at the edges, corners have 2 edges so they are even more susceptible.
Scooter
United States - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
12/24/2007 10:43 AM
The corners of the sheets have a greater kinetic exposure to the bulk plating solution (edges have less, and the centers of the sheet faces have the least). As known in the field of heterogeneous catalysis (chemistry at solid/liquid interfaces), extended flat metal surfaces essentially behave like 2-dimensional objects and therefore have less access to species dissolved in solution than do surfaces with a more 3-dimensional shape (i.e., greater surface curvature and/or point-like regions). To remedy this, try more vigorous stirring of the plating solution.
Problems worthy of attack prove their worth by hitting back. -- Piet Hein
12/22/2007 5:56 AM
Your actual problem seems to be metallic contamination of either Copper or Zinc and in some cases lead if the color of spot is greyish. Remedy for this is to reduce the pH of the abth to below 3.0 and perform Low current dummy electrolysis with a corrogated sheet and observe the sheet at regular intervals after a certain period of time your dummy will be normal this indicates the absence of contamination. Then increase the pH to the normal range and start working. this will definetely solve the problem.
Praveen
Mumbai
Anonymous Poster (3); case491 (1); Macker (1); praveen0109 (1); snewkirk (2); svengali (1)
