Previous in Forum: Advanteges of XLPE Insulation in Power Cables?   Next in Forum: responder 210
Fluorescent ballast applications
11/15/2007 8:26 AM
Greetings!
We have a problem your genuises might help with. Our company (in the USA) is designing a device that can be installed in cool & potentially moist environments, among other places. The device will have a number of fluorescent lamps inside. Our problem stems from choosing a ballast. The ballasts will be located inside the product's housing, although not in any sort of particuarly sealed enclosure. Depending on the design, ambient air may or may not be pushed across them. We understand there are Type 1 & 2 ballasts although we're a bit foggy on the precise differences. Do we technically or legally need to use a Type 2? True "Type 2" ballasts seem hard to find, although we have seen a few marked "Type 1 or 2" (which means what?)
Anyone here care to shed some light? (no pun intended)
Re: Fluorescent ballast applications
11/16/2007 2:37 AM
I think type1 or 2 is only the supplier coded numbers. In T/L ballast there nothing such standard. A T/L ballast can be conventional or electronic. In conventional copper wire/ Aluminium wire are the two type. In copper some are making energy efficient chokes. My advice: since the ballast you going to use will be fitted in some what moist and cool environment, use a ballast that do not have any connectors where wires are to be screw tightened; instead buy a sealed ballast through which two connecting wires came out to be connected to tube and then to power.
11/17/2007 10:18 AM
Decades ago-all Iron-cored Choke(Ballast) makers offered "Polyester" types.
Meaning the ready Ballast potted in Polyester?
Or was the Polyester referring to the wire insulation?.
Must have been to survive Humid environments.
In India today ,Steel armatured Cu/Al coiled Chokes(Ballast) is rare. Everyone is selling/buying Electronic Choke(Ballast).
