Previous in Forum: I@E TECHNICIAN   Next in Forum: Differential pressure Transmitter
Temperature sensing...
11/15/2007 7:08 PM
Is there a hand-held sensor that can detect a 20 degree increase in temperature through 1 foot of permiable soil?
United States - Member - USA Engineering Fields - Control Engineering - Never enough money
Re: Temperature sensing...
11/16/2007 1:15 AM
Short wave length thermal camera.
11/16/2007 3:04 AM
Temperature sensors are sooooo cheap. A sensor on a 1' spike will do it very quick accurate and cheap.
11/16/2007 4:25 AM
Any hand-held thermometer over 1ft in length would do the job. Contact 'Stinky Pete' offline. He might have one in his skip that you could have.
Innuendo is not Italian for a suppository.
Good Answers: 74
11/17/2007 12:33 AM
It would possibly emit a burping sound when reading the required temperature. There are very cheap sound emitters on the market.
The Twain Has Met
11/18/2007 2:58 PM
Guest,
are you looking for a sensor that can detect temperature variations by a factor of 20 degree as input and given to controls or data loggers or just measuring instrument to read temperature 1 foot beneath , there are loads of instruments and sensors that are quiet cheap , even normal mercury thermometer can do the job
11/19/2007 2:58 AM
This is a bit blurry: you want to detect a diffrence of 20°C no problem, even your hands can feel the difference.
But this happens below 1' of soil.
A thermal imager can show you difference but only in surface temperature. it will take some time before the effect is seen on the surface.
If you need to trace a pipeline/object which should be 20° warmer than the surrounding soil: no problem. go for the thermal imager, or wait till it snows.
Gwen.Stouthuysen (1); Horrible Old Bat (1); ky (1); Richard L (1); user-deleted-1105 (1); vikas (1)
